Been getting shit done on this you homosexual? I want to see more than a roll cage.
The clubman you speak of uses a mid mounted engine I think. I've switched the engine around and put it in the normal spot
In the build AE86 v2.0
Hiroshima Screamer
Super Lap Special
I was in melbourne over the weekend. So not alot done but starting to machine up various adapters and fittings for the front suspension
Hiroshima Screamer
Super Lap Special
Similar to the old set up, apart from the shockers?
whats the body weight with all those tubes ? guess about 550kg ?
not sure haven't weighed it and not really to concerned about it either, min racing weight for me is 1050kg's so i know i'll be under anyways.
Hiroshima Screamer
Super Lap Special
man i need some new pants!
this thing is fucking awesome...
Hiroshima Screamer
Super Lap Special
ok i'm back and i've done some more work. I've been nutting out the front end and i pretty much have it all done, the steering rack has to be moved, not real happy with steering angles, and i need to machine up some spacers for a few bits and pieces. So like i said pretty much done. here's some pics.
lower ball joint is a spherical bearing, i had to machine up the adaptor to fit where the ball joint would be on steering knuckle, i can adjust roll centre by adding and/or removing spacers
I did not want to weld to the strut body, even though they are the inverted style insert, so i had to make this clamp style mount, alot of fucking around but worked out really well.
the clamp from another angle
Here you can see nearl evrything, strut, hub, lca, and castor rod, everything is adjustable
heres some pics of the lower control arm, made from 1 1/4" cr/mo tube and 3mm cr/mo sheet, might look a little chunky but actually quite light i run a larger dia tube so i can use a thinner wall, just need to put sway bar link mounts on it, but i'll work that out when i make and mount the bar.
Hiroshima Screamer
Super Lap Special
