Results 1 to 6 of 6
Thread: sw20 to ae86
    Veteran Dom86's Avatar
    Dom
    Balga
    Default sw20 brake lines into ae86
    Anyone know if MR2 SW20 Braided Brake Lines will fit/work with an AE86??
    Jonathan
    All Toyotas use the same brake threads (which is M10x1) so they should fit.
    A main difference is that some Toyota brakes use a banjo fitting (eg ZZE122 Corolla) and a banjo bolt on the brake caliper. Even tho the AE86 does not use a banjo fitting standard, some people choose to use a banjo fitting, and it sort of works.
    I have found that on a AE86 with either standard or RX7 brakes, the banjo style fittings makes the brake line fit a bit funny. Normal screw in style works better.
    For the clutch, if you have a 4A-C belhousing, a banjo fitting should be used for exhaust clearance.
    Dom
    Balga
    Thanks Jonny.
    In the event that they don't screw in, do you think i would be able to get fittings to make it work with out chopping them up? Sort of adaptor style.
  • #4
    lol should the heading be:
    Sw20 brake lines into a ae86
    or
    Brake lines: Sw20 to ae86
    My impression was a engine swap
  • #5
    Dom
    Balga
    Your prob right......
    DONE!
  • #6
    lol i just thought it was an engine swap
  • Similar Threads
    1. wanted: SW20 shocks for ae86 AND strut tube spacer technotoy
      By khai2298 in forum Cars or Parts Wanted
      Last Post: 30th May 2012, 07:42 PM
    2. [NSW] swap S1 Rx7 13b for AW11, SW20, AE86
      By furstydrft in forum Cars for Sale (Not Toyotas)
      Last Post: 15th October 2011, 11:47 PM
    3. MR2 SW20 caliper mount brackets to AE86 strut
      By Bozu in forum Car Parts For Sale
      Last Post: 2nd May 2011, 06:28 PM
    4. Xt130 coilover, Sw20 KYB AGX, AE86 Cusco camber plater, etc...
      By xsoarerx in forum Car Parts For Sale
      Last Post: 17th April 2010, 11:56 PM
    5. sw20 coilovers into ae86
      Last Post: 28th April 2007, 07:21 PM
