Results 1 to 10 of 10
Thread: 4ac valve clearances wanted
    Adz
    Default 4ac valve clearances wanted
    as topic, valve lash clearance settings are required. im sure somebody out there knows them.
    Senior Member Dylan's Avatar
    Dylan
    hey,
    they are : Intake - 0.20mm (0.008 in.)
    Exhaust - 0.30mm (0.012 in.)
    Thats with the engine warm aswell.
    Adz
  • #4
    Kieran
    isn't that the same with the 4KC?
  • #5
    Dylan
    it is yeah
  • #6
    Kieran
    cheers, just adjusted mine today
  • #7
    Ryan
    Austins Ferry
    what are they cold?
  • #8
    Kieran
    pretty sure they are the same
  • #9
    Dylan
    just set them with a little more clearance to allow for heat expansion of the valve
  • #10
    Ryan
    Austins Ferry
    yeh, i did em last night just got the engine going in the end and warmed it up, made it a little quieter. cheers.
  • Similar Threads
    1. 20 valve manual ECU wanted
      By terryo in forum Cars or Parts Wanted
      Last Post: 1st April 2012, 08:20 PM
    2. Valve shim clearances.
      By ae86 slide in forum Technical - Questions
      Last Post: 19th May 2010, 11:16 PM
    3. 4AC valve clearance
      By 84AE86 in forum Technical - Questions
      Last Post: 17th April 2009, 08:42 PM
    4. 4ac valve clearence specs??
      By TOY3TG in forum Technical - Questions
      Last Post: 17th February 2009, 08:43 PM
    5. Timing and valve clearances 3A-U
      By David in forum Technical - Questions
      Last Post: 12th July 2006, 09:26 PM
