Does anyone know what that is ^ Two lines that run over cam over.
Beige!
It's got ill fitted king springs all round too! SICK KENT
This will awesome dude! I'd rock stock Bigport at first, like you said, so you can drive it. Get everything else sweet first, drop in built 7A later.
^this.
first to say this, needs more skids, lol
~KEEP DRIFTING FUN~
marv.
keep it simple and drive the shit out of it.
<3
yes i agree. those will be for powersteering weight adustments like lucifer said. provided they run to and from your psteer pump that is :p
standard ra65 rad is heaps bigger than that. u can have mine as soon as i put all the lcas etc in my ra and can fit the maxima rad. I had its end tanks replaced a few years ago so i dont see it failing anytime soon.
loving the jap spec accessories, speeding alarm. so rad. 65kmph tho, that thing is going to fun police u good.
So just keep in mind the next time ur at a drift meet and someone asks u why ur not out there ripping it up with the other sikunts, don't say "I'm waiting for my coilovers to arrive" or "my gf wont let me drive sideways", u say "I flatspotted my tyres on my HUUUGE 120km/hr entry and if u missed that then ur TOO LATE BIATCH"
Thanks! I might rego in NSW, as I don't want it impounded.. Hard as it's plated for QLD?
That is sorta the plan... for now.
LOL
I got some bare bigport heads chilling here which I am going to clean up around the valves and combustion chamber (both are pretty restrictive), wack the running gear on it, do valve seals and others.. I will check to see how this bottom end is.. I might just have to wack another piston in it or rings.. But if I need to do ring and bearings I will probably put a 7afe bottom into it and just rock new rod bolts on it, as it's not going to rev over stock limiter @ 7300? 0r 7500.
Took the battery out yesterday and there was oil all over the tray..
