Results 1 to 10 of 10
Thread: clutch peddles for a ke70
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Default clutch peddles for a ke70
    I am sure this has been covered before but I searched and I couldnt find it.
    I want to know what clutch peddle/peddle box can I use to convert a ke70 corolla to have a hyraulic clutch. I know ae86 and ae71 are an option but they are too hard to find, can I use something celica or t18?
    Nathan
    Lilydale
    i beleive t18 can be modified to fit. i have one if you want one sam!
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    you can use any hydraulic clutch setup. you are pretty good at fabricating. you should try modify the std pedal box into a hydraulic setup.
    FTP.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by Sprinter86 View Post
    View my tech article for more info:
    http://www.ae86drivingclub.com.au/fo...ead.php?t=2008
    Scammer, DO NOT BUY FROM ME!
    i remeber there was that green 12a powered ke70 in nz that had the std peddle box modded to be a hydro setup, ill try find the tech article on it
    Endeavour Hills
    thanks nath but I will see,
    clinton your right I might have a chance to just mod the standard one but I dont have the time and options I used to so I prefer to just fit something that works straight out. However I might as well have a quick look and see whats involved.
    Endeavour Hills
    Golberg: thanks for the link, very helpfull. I also see the right way to spell pedal now that actually would of got something in a search
    sonsta: would be good
    Member yakusikimo's Avatar
    Mat
    have you guys seen those pedals used in track cars where they are mounted to the floor and pivot from there, also the master cylinders are directly behind inside the cabin sometimes. im wondering if u could just get the clucth and if its a viable option?
    Veteran driftke70's Avatar
    Ryan
    Buderim
    the clutch setup im running is out of a stadium truck, and has an inboard master cyl from GT4 celica.
    wheelfriends.wordpress.com
    Endeavour Hills
    Quote Originally Posted by driftke70 View Post
    whats a stadium truck
  1. WTB- Lexus SC300 Peddles & assembly.
    By raceAE86 in forum Cars or Parts Wanted
    Last Post: 12th January 2011, 09:32 PM
  2. KE70 Clutch cable
    By starni_boy in forum Cars or Parts Wanted
    Last Post: 23rd September 2009, 03:46 PM
  3. which clutch to use in a ke70?
    By grape_moosha in forum Technical - Questions
    Last Post: 7th March 2008, 05:16 PM
  4. ke70 clutch
    By Sprinter_Seth in forum Technical - Questions
    Last Post: 29th May 2006, 11:02 PM
