hey i have ajps 7kg prings for front, what chocks would you reccomend for them and how much?
Kaizen Garage is pleased to offer the following special AE86DC pricing on KYB's excellent AGX adjustable shock absorbers:
Shocks
765015 suitable for normal to low front coilover conversions - $205 each
765016 suitable for slightly longer coilover setups as well as MX73, XT130 etc $205 each
741015 8 way adjustable suitable for rear shock and rear coilover applications (needs accessories) **$210 each on special (4 only) normal price $245
Accessories
Fine thread gland nut (front shocks come with a coarse thread nut, AE86, MX73 etc require fine thread) $10 ea
Rear AGX fitting kit (new top and bottom bushes to mount these shocks) $45 per pair (enough to do both rear corners)
Dimensions
Some dimensions to help select the right shock for your application:
The 765015 has a body length of 338mm, a compressed length of 348mm and at full extension is 509mm.
The 765016 has a body length of 360mm, a compressed length of 370mm and at full extension is 542mm.
Cheers,
Anthony
The best shock depends on exactly what youre doing to the strut length-wise etc. Probably the 765016 AGX if the lengths are going to work out. PM sent.
Are you able to supply shorter-than-factory stroke shocks for a jzz30 soarer?
Havent really looked into the dimensions/case sizing of the Z30's. Most people just get coilovers as theyre so plentiful. Do you have any dimensions?
None sorry. If you cant do it thats fine just wanted to ask
hey ant do you have to tools/willingness to cut down struts to make coilovers? keen to get the shocks off you but just need someone to do the labour
got any pic of the rear setup/shocks??
