For my fellow admins: this has been given the Nick seal of approval
Just making a post to see if people are interested in two products that might be in the works.
Pan-hards: using very tough rod-ends for both sides with on car adjustment. Option of rubber boots to protect the ends.
These would be very rigid and in a light steel construction. I estimate these would be around $150 without the rubber boots.
16V coilpack plates: An aluminium plate that replaces the original 4age 16V plate between the cam covers to hold either 1NZ or 1ZZ coils in place. It would bolt right in place.
I have 2 possible customers and I want about 4 before I decide to go ahead with and make some. Constructin would be profile cut aluminium plate with a second bolted peice at the end and would roughly be also $150 each.
