Results 1 to 5 of 5
Thread: fault codes
    shannon
    PERTH currently
    New Zealand
    Default fault codes
    hey all, iv got a 83 ae86 its stock in the engine department (blue top 4age) but ever since iv had it its had a high idle (13-1400), its starting to seriously piss me off.
    its always always thrown fult code 11 which apparantly is this
    code 11
    Switch signal
    Diag: Air conditioning switch and IDL point in the throttle position sensor is ON (not regestered in memory)
    what the hell does that mean??? iv just tried a new TPS but nothng has changed. still throws the code still idles hgh
    any ideas????
    thanks guys
    cold idle switch?
    something to do wth it thinking it has a'c load on the engine?
    shannon
    PERTH currently
    New Zealand
    yeah thats what i thought, but the AC works as it should, cuts in and out etc
  • #4
    Gone
    Joel
    Picton
    have u tried setting the tps up properly, download the manual. if the tps it not in the right position it will effect the idle.
  • #5
    Jonathan
    Good point. Put a multimeter on the TPS and adjust it.
    But that will only fix a fault code, not the high idle.
    With A/C off, adjust your idle speed with the bleed screw on the throttle body, flat screwdriver. It maybe under a rubber plug, but often the plug is missing.
  • Similar Threads
    1. ecu fault codes
      Last Post: 12th August 2012, 12:39 PM
    2. Simple electrical fault?
      By Jkabs in forum Technical - Questions
      Last Post: 9th May 2012, 10:29 PM
    3. 16V ignition fault, at regular intervals
      By ke70dave in forum Technical - Questions
      Last Post: 20th November 2009, 10:08 AM
    4. Not Holding Tune + Electrical Fault
      By tc-rolla in forum Technical - Questions
      Last Post: 28th October 2009, 09:04 PM
