Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thread: which tailshaft for a ke70 wagon
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Default which tailshaft for a ke70 wagon
    I want to fit a T50 into my kE70 wagon, can I just split my current tailshaft and the front half of any T50 tailshaft on? or cant they be split?
    AE71 should be ok to use?
    Endeavour Hills
    if I can use both a sedan and wagon tailshaft is the big question
    There are usually no flanges to seperate it, you will need to get an ae71 tailshaft or have a tailshaft made.
    Dave
    Quote Originally Posted by Matt-AE86 View Post
    almost correct...
    you can split KE tailshafts. there is a chunky bolt inside the uni joint, you can only get to it with a spanner.
    as can be seen in my little diagram here
    http://i168.photobucket.com/albums/u...splitshaft.jpg
    i split my ke tailshaft and tried to join a ae86 tailshaft to it by joining it at the spline in the uni joint.
    it was all going well untill i realised that the ae86 one had a bigger spline, it wasnt much though maybe 2 teeth.
    anyway...as for your problem sam...i reckon you could get a sedan ae71 front half, and add it to your wagon rear half and join them?? just dunno if ae71 and ke70 have the same spline....
    it might pay to meausre the distance from your gearbox end to where it joins and then get a hold of an ae71 one and measure that too?
    Endeavour Hills
    thanks for the great info dave, I will make that measument but I will have to be patient as AE71's are not easy to come by.
    Senior Member adam's Avatar
    Adam
    You could measure my tail shaft when I drop by, Sam. Or I could measure it for you, just let me know where you'd want it measured from, etc.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
    I have a KE70 pannelvan tailshaft here, keep in mind though they use a S series diff, not a borgy. If you think you could use it, let me know.
    Endeavour Hills
    adam: thanks I will get back to you on it
    matt: thanks but no I need one off an ae71, I am guessing what you have off the pano is exactly what I have already on my ke70 wagon
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by Sam-Q View Post
    No its entirely different, wagons have a borgy diff, pannos have an S series. Pannos usually have a 1 peice (no centre uni either)
    But you're right, any AE71 one should work... unless you are going to use a T18 T50.
  1. KE70 to 4age conversion parts and ke70 wagon wrecking
    By Sam-Q in forum Car Parts For Sale
    Last Post: 3rd August 2012, 09:41 AM
  2. Replies: 5
    Last Post: 2nd September 2011, 01:13 PM
  3. WTB: SA - ae71 wagon diff OR panel van tailshaft ASAP
    By AJPS in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 08:46 PM
  4. Ke70 auto tailshaft, ke70 slanty headlights
    By armc89 in forum Cars or Parts Wanted
    Last Post: 10th August 2011, 08:43 AM
  5. AE71 Wagon Tailshaft,16Momo wheels,AE71 front and rear bars
    By Ramcam in forum Car Parts For Sale
    Last Post: 14th December 2009, 06:40 PM
