Maybe if you have an S series shaft lying around and an S series diff, lop all the mounts off and bolt it up to the wagon. Just an idea.
EDIT: or get creative and put 4 link in![]()
oh yeah your right I tottaly forgot about that, and no I have my original AE86 T50
like someone else said, t18 t50 will work with the ke70 wagon tailshaft, the ke70 sedan and wagon are exact same tailshafts, can only assume the ae71/ae86 swap into wagons too. (obviously ae86 with s diff)
so basicly I take the box out of a t18 or a ta22, fit that with the right bellhousing then use my existing tailshaft?
TA22 one is crap, shifter location is different. But a series 1 T18 should do the trick (series two I am told are 22 spline), although you'll more than likely have to slightly modify the A series bellhousing to get it to fit perfectly.
There are a few threads on toymods about fitting an A series bellhousing to an early T50, best to have a look there.
I thought the TA22 and the T18 boxes are one and the same thing? I dont mind moving the shifter hole
Its a long way forward, but if you don't mind hacking into your floor go for it... Although the stick may very well hit the dash.
so the ta22 one is on the left? now I know this is a realy difficult question but any idea on how many mm there might be between them? because in the photo they look the same and they obviously arnt
No no, they are both TA22 versions, hence why they look so similar. Should have specified sorry.
An AE86/AE71/T18 shifter sits slightly over the edge of the cup at the back of the box.
Roughly around 100mm, probably a little more toward the back of the box.
EDIT - Even better, JDM AE86 box:
It may be possible to swap extension housings from your AE86 one onto a TA22 variety.
wow ok, I will have to do some measurments and see if it will work for me, your pics here will be usefull and thanks for the info
