Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: drill bit sharpener
  1. #11
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    use your mits its not to difficult its a good life skill out of 1000 people in the machining business i guarantee only about 10 could do it by hand thank god im not one of them
    the dyno pull to 300rwkw
  2. #12
    Adan
    Oxley Park
    Same as what everyone else is saying, its one of those things youd want to learn if you have half an interest in what youre doing.
    When I started my apprenticeship, our tafe teacher made us make a quick angle template which we used for drill bits, welding prep and a whole range of stuff, maybe make one and go crazy.
  3. #13
    Aaron
    In the Mountains
    okay i tried again on the bench grinder, got 1 win! bit went farken woosh threw the steel. tried another bit. fail, then fail then fail then whoosh. think maybe i just need to do it a few more times.
    vid was mildly helpful but my sound doesn't work for some reason so couldnt hear his flapping gob.
  4. #14
    Jun 2013
    Ella
    Ballarat
    There are all kinds of complicated jigs and gadgets out there for sharpening drill bits. But the fact is, twist drill bits are actually quite easy to sharpen by hand. And if you mess up, the worst that can happen is that you grind away a few millimeter of drill until you get it right.
  1. Anyone have a 9mm drill bit, and a 10x1.25 tap?
    By Gunner in forum Sydney & NSW Events and Discussion
    Last Post: 9th July 2012, 01:20 PM
  2. Pedal Box Holes. Where to drill?
    By ke70 xx in forum Adelaide & SA Events and Discussion
    Last Post: 1st July 2009, 07:11 PM
  3. Left Handed(Reverse) drill bit
    By Jase86 in forum Tool Talk
    Last Post: 5th April 2009, 12:07 PM
  4. spot weld drill
    By johnk84 in forum Technical - Questions
    Last Post: 24th March 2006, 10:16 PM
