Results 1 to 10 of 13
Thread: No Spark 4age bigport?
    Senior Member KE70's Avatar
    Alek
    Lalor
    Default No Spark 4age bigport?
    Im in the process of starting my fresh install of a 4age, I just have a few wiring questions/problems.
    There is no spark while i am trying to start the car.
    Ive followed the wiring diagrams to the best of my knowledge but im not 100% sure.
    Is there anyone in melbourne that knows 4age wiring looms? lol
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    run a wire staight from the positive side of the battery to the positive side of the coil. does this do anything?
    FTP.
    Veteran shift_rook's Avatar
    SE Burbs
    lol, check the melbourne guy thingy, sprinter86, nathan, couldn't reccomend him more, moderate pricing and does a top job.
    Alek
    Lalor
    Thanks for that, PM sent to sprinter86
    Senior Member orido's Avatar
    Orido
    outtheback
    home troubleshooting ftw
    Gone
    Joel
    Picton
    no spark at all or just piss weak spark? check coil power and resistance, check ignitor, need to also check the trigger resistance in the dizzy, check main efi relay and fuse.
    download the diagnostic manual for the how to's, its a piece of piss, all u need is a multi meter and 2 x 1.5 volt batteries (test ignitor) and your sweet
    oh and make sure u have good earths, if u have intalled a new coil..like a gt40r make sure u file some paint from the casing to ensure a good earth, trust me if u dont your spark will be ghay and it wont start!
    Senior Member Brendan's Avatar
    Brendan
    Not dodgy leads or dissy cap?
    Alek
    Lalor
    Quote Originally Posted by sundee86 View Post
    I will try all these things hopefully tonight.
    Just one more question, does the ECU need a signal wire? apart from the normal power and accessories power.
    What i am thinking, the coil is not getting a signal to starts sparking somehow.
    Alek
    Lalor
    Ok we got it started It turned out to be a ground wire to the ECU.
    Thanks for your your help guys.
    Just need to sort out the issue of why it wont rev over 2Krpm, just checking the timing now.
    Alek
    Lalor
    Its all good now, the timing was way out.
  1. [VIC] Bigport 4AGE Block, Intake mani and spark plug leads
    By 4ABHGE in forum Car Parts For Sale
    Last Post: 22nd June 2012, 01:51 PM
  2. Spark plugs for 4age
    By DearmanKE in forum Technical - Questions
    Last Post: 23rd December 2011, 02:39 PM
  3. 4age spark?
    By AE86R in forum Technical - Questions
    Last Post: 30th March 2009, 02:42 PM
  4. No spark 4age
    By rthy in forum Technical - Questions
    Last Post: 20th January 2009, 01:22 AM
  5. bigport spark lead cover...
    By DRFT - 86 in forum Cars or Parts Wanted
    Last Post: 19th January 2007, 10:48 AM
