Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: KE70 Clutch -> Hydro
  1. #11
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    thats awesome! top work.
    bursting ovaries since 92'
  2. #12
    Alex
    Wagga Wagga
    Okay, I know it has been a while since I updated this, but I have only recently bleed the clutch and been able to drive it.
    So far from my minimal driving, there seems to be no issue with the firewall flexing etc. Obviously it may change when it is getting abused/kicked, but I will report on that later. For the moment though, with normal driving, it operates perfectly
    My only change (personal preference) will be to replace the standard pedal return spring with a slightly stronger one. The stock one works fine, but I'd prefer if the pedal felt a bit more firm/harder to press.
    Alex's 4AGTE KE70
    Or so was thought...
  3. #13
    Senior Member sld sho's Avatar
    Sep 2010
    Ozman
    Broadmeadows
    would you be intrested in makeing another one of these?
  4. #14
    Nichy
    Launceston
    old thread i know but any more info on this ?
    did you end up having to make a new brace for the fire wall?
    will be trying this on mine
  5. #15
    Veteran Nikkojoe's Avatar
    Tom
    I know someone who recently did a setup like this and the firewall cracked after a track day. Had to hammer the firewall back in and brace up the master.
    Do it once, do it right. Just get the right pedal box!
  6. #16
    Alex
    Wagga Wagga
    Updating as I re-found this thread. Sorry for the late reply Nichy (if you even see this
    Still running the above pedal box. Have done a track day at Winton in the mean time, as well as heaps of 'normal' driving.
    No issues at all yet. Will report back if there happens to be.
    Alex's 4AGTE KE70
  7. #17
    Nov 2015
    Michael
    Werribee
    I know this is a massive thread dig, but I thought id ask my question here instead of starting a new thread.
    I am by no means a mechanic or very mechanically minded. Can anyone explain to me why when converting to an 4AGE engine in a KE70 do you have to convert to a hydraulic clutch also?
    This is probably a very novice question, just wondering. Is it simply because the gearbox you use with a 4AGE must be hydraulic assisted and cant be used with a cable?
  8. #18
    Because the box behind the ke70 will not bolt up to a 4age block and the bellhousings can't just be swapped over.
    the fork setup behind a t50 doesn't accept a cable.
    you could perhaps make something which holds the clutch cable in the correct place with a custom fork and not swap it I guess
  9. #19
    Bryan
    Waterford
    Tramore
    Ireland
    Flo in Ireland offers this for 4AGE powered KP61 Starlets so it should work in a KE also
  10. #20
    West
    Lets spend a bunch of money to downgrade to a cable clutch. 120 pound plus freight its cheaper and gives you a better result to buy an ae71 pedalbox and go hydraulic. No ripping out the gearbox to reconfigure everything either.
  1. Hydro Handbrake for a ke70
    By ke70 xx in forum Technical - Questions
    Last Post: 26th May 2011, 07:43 PM
  2. Wtb >> ke70 or ae71 adelaide !!!!
    By ke70kid86 in forum Cars or Parts Wanted
    Last Post: 9th January 2009, 07:21 PM
  3. WTB: hydro clutch & pedal box
    By twin_cam in forum Cars or Parts Wanted
    Last Post: 10th September 2007, 11:31 PM
