Results 1 to 10 of 13
Thread: t series diff and 4K??
    Ridgehaven
    Default t series diff and 4K??
    Hey just curious if I can run a T series diff, with just a 4K and 5-speed box?
    diff is on the way out and have an engine conversion planned later down the track which will require a diff upgrade anyway. figured I may as well go t series
    Cheers, Ben.
    Veteran shift_rook's Avatar
    SE Burbs
    you'll most likely have to run a custo tailshaft unlsee you can bolt together a kesev and a t-18 diff, might have different splines though, i wouldn'tput my money on it.. so yeah probably just custom tailshaft but apart from that it should bolt up
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    you can.
    but do you mean as in like with bolt in parts?
    if you do, something about a series 1 T-18 tailshaft will work . like it will slide into the gearbox or the back half has the same spline for the front half of a k50 or something.
    or as in actualy diff will bolt in?
    yes, its a direct replacement aslong as you get a series 2 rear end. series 1 you have to weld sway bar mounts onto it.
    a t series is like super overkill for a 4k though. if i was you id just keep the borgie in there and hammer it untill your ready to do the whole conversion and then do the diff then aswell.
    but hey, if you want to muck around with these ideas go for it.
    FTP.
    Ridgehaven
    Yeh hey I realise a t series is overkill for a completely stock 4K but I may as well only swap diffs once instead of twice if I can
    so possibly series 2 t18 diff, and series 1 t18 tailshaft may work with 4k and 5speed
    Cheers, Ben.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I have been told that a complete T18 tail shaft will make it happen for you. Apparently the K50's are the same 20 spline as the T18 T50's. Cannot be certain though, but it would be your best bet, otherwise custom shaft.
    Jonathan
    Yes, but it has to be a early T-18.
    Lawrence
    Wollongong
    Series 2 use 22 spline? Didn't know that one.
    Ridgehaven
    Quote Originally Posted by Golberg View Post
    so there the same spline, same length and shit?
    also t18 diff is same length as ke70 diff? wont affect wheel fitment?
    Cheers, Ben.
    SE Burbs
    dude make sure you check it out beforer you go buyin shit, cause sometimes little idea's pop into peoples heads then when they say it works they have 5 people agree with them, not saying it won't work, just make sure it does before you throw dosh into it
    Ridgehaven
    Yeh no shit
    cheers mate
  1. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  2. Replies: 14
    Last Post: 4th June 2012, 07:16 PM
  3. WTS F Series Diff & G Series Diff
    By PRIMRK in forum Car Parts For Sale
    Last Post: 21st January 2012, 12:57 PM
  4. Replies: 1
    Last Post: 15th January 2012, 09:11 PM
  5. (SA) S series diff centre, stock ke70 4k inlet manifold
    By iwantarolla in forum Cars or Parts Wanted
    Last Post: 13th April 2011, 10:40 PM
