waht coil you using??
Hey guys I'm in the final stage of the 4AGE conversion in my KE70 and I can't get spark? I looked in a 4AGE manual and the coil pack is supposed to have 12V when ignition is switched on so I ran a direct line from a 12V ignition power source and tried cranking it over and still no spark.... Am i supposed to connect some other power source from the original loom or?
PLEASE HELP ME!
also you should be suplying your injectors with power it is the blank with orange stripe wire that is on your engine loom (should be under your dash near your ecu) this will power injectors and coil
thanks guys for you help! I'll be searching for this black with orange stripe wire on my 4AGE loom but i think i've already supplied power to the injectors (B1, +B) from the ecu? or is this seperate?
Btw it is an AE82 coil.
supply power to the positive side of the coil
supply power to B1, +B and BATT on ecu (BATT is the red with white trace)
you MAY need to supply power to the yellow wire on teh ecu, which is shown in the link that i have provided.
If you follow the guide that we have posted you cant go wrong.
if still no power ur dizzy cap could be rooted, and check that the plug coming out of ur dizzy is connected properly
