Full factory cold air inlet including plastic snorkel, vgc. $280 inc post.
JDM AE86 Vapour canister and purge setup - $50
Trueno front of body loom and underdash loom, complete uncut plug and play, with fuse/relay panels from the kicks and under the column. - $300 inc post.
AE86 Bare struts with springs, tops and dampers. vgc - $180
AE86 LCA - average ball joints - $20
4age to t50 bellhousing bolts. New. $25 posted to you in Autralis. One set sold, one set remains.
AE71/AE86 engine mount cover plates satin blk powdercoated $ 15 each. 2 left
AE86/AE71 Steel engine mounts. Powdercoated satin black. Looks mint, had some casting dags filed off before coating. $60 a pair. - 3 pair available.
Toyota ECU bracket - satin black powdercoated - $15. 1 only available
T50 rubber gland plate (bit that bolts into the floor of the car with the rubber boot under it) - Satin black powdercoated - $ 10 - 2 available
K series Metal stone/splash tray - looks awesome in satin black powdercoat- tidy up a ke70 bay! - $50. 1 only
AE71 gauge holder, bolt into factory holes - $40 - 1 only.
20v alt mount modded for rwd then powdercoated. $35 each 2 of
AE86 tow hooks satin blk - $60 pair. 1 pair only
AE71 Crossmember - Satin powdercoated - $130 - 1 only
AE71 Gearbox crossmember - Satin Powdercoat - $80 - 1 only
AE71/AE86 rubber mounts - used, average condition - $20 pair. 2.5 pairs available
Call me 0416 193 936
Some stuff sold already, first post has been edited with all remaining items.
