Results 1 to 10 of 18
Thread: big differences in roll centre...
    User fantapants's Avatar
    Pat
    Default big differences in roll centre...
    curious about something guys.
    my understanding of bump steer was DIFFERENCE in the arc of the of the lca and the steering arm. as they ravel through their suspension arc, one travels on x radius and the other on y radius and the resulting change i toe is bump steer??
    with that in mind, what would be te likely results of a BIG difference between these arcs?
    i have s13, and i am aware of the problems associated etc etc etc. i was looking at the max steering knuckles as one of the issues i have had is the steering rack forming a solid line and tightening up. These provide 2 inch of drop on the knuckle, but i can only get a max of 35 mm rca ball joint for the lca.
    i have also seen the same setup used without any rca for the lca??? what sort of effect would this have on overall handling?
    so what say you oh masters of grip??
    pat
    06/07/2011
    Veteran driftke70's Avatar
    Ryan
    Buderim
    angle grinder
    wheelfriends.wordpress.com
    Pat
    yeah besides cutting the tip off my finger what would i do to it?
    06/07/2011
    Veteran slydar's Avatar
    Dimitri
    dont know about angle grinder. pretty sure you can remedy youre little problem with a spanner. lol.
    jokes aside. have you had a good look at the relationship between the lca and tie rod, the way it is now?
    i have noticed these sorts of nissan alignment products dont seem to be marketed as a system.
    i cant really give an impression as to why, as i havent had a look at the s13 stuff when lowered, not in an s13 anyway.
    possibly, when lowered, and more so, when a lot of caster is wound in when lowered, the steering knuckle arm angle is changed enough that a miss match in these products "heights" is required to return the alignment of the 2 arms (lca, and tie rod) to closer to their correct relationship.
    should be noted, that even for ae86s, where a simple spacer (rca) can be used to manipulate both pivot points at once, there are still available after market tie rod ends for fine tuning of the relationship between the 2 arms.
    ive personally never got that far into it.
    http://store.autosportsupplies.com/m...tegory_Code=SP
    thats them.
    having the s13 stuff in an ae86 though, kinda puts you out there on your own somewhat. kinda uncharted territory. you might need to make friends with Adam. not an easy man to make friends with. lol. but no im sure he could give you some better insight.
    Daniel
    GC Hinterland
    i read that a couple of times and im not exactly sure what you are asking.
    Yes, any difference in the steering arm arc to the lca will create toe in/out on bump which is the bump steer you talk about.
    Correcting it is a little tricky, and usually a case of trial and error, especially when dealing with a mish mash of componentry.
    Correcting this may involve a number of approaches
    moving the steering rack foward/backward, up/down
    modifying the lca pivot point
    adjusting the static height of the steering arm/lca
    The indicator of what is going on is to build a simple gauge to show what the toe is doing through the suspension range. It is simply a hinged bit of wood (say 2 pieces 40 x 40cm) with 2 screws that point to reference areas eg the outer lip of the rim. with the front springs removed raise/lower the car in increments to identify the toe during bump/droop.
    when you have done this you canbegin to rectify the problem
    Pat
    yeah i sometimes get lost in my own awesomeness... i mean badly worded questions
    my main queery is how gnarly an effect would a static height difference of about 2 inchs?
    and yea i would rather eat arse than grovel to adam lol. ill figure it out myself befor that!
    THANKS FOR THE INPUT GUYS.
    06/07/2011
    carbonae86
    http://www.nissansilvia.com/forums/i...owtopic=360823
    fanta what is it with you and the male ass
    Pat
    meh male donkeys female donkeys??? all donkeys to me
    yeah i know about that page and have looked into most of the stuff on there, howvere most dont have anywhere near level suspension arm arcs when applied to the max setup.
    i have spoken to the guys at max and i think it is something along the lines of what dimitri suggested, that the changed angle etc etc etc and a change in the positioning angle of the extension works in a less than clear fashion, but the guys do say it works
    ps do i know you?
    06/07/2011
    carbonae86
    would they have suggested sticking the car on a bumpsteer guage first ?
    ps i dont know any persons that are into paddlin
    Pat
    already been suggested abpove and done....
    and your missing out
    06/07/2011
  1. Wanted ae86 roll centre adjusters
    By zookieboi in forum Cars or Parts Wanted
    Last Post: 11th December 2012, 07:21 PM
  2. ae86 - rt142 roll centre adjusters - 35mm +
    By nichy in forum Cars or Parts Wanted
    Last Post: 22nd March 2011, 10:18 AM
  3. roll centre adjusters, ke20 parts
    By Roo. in forum Car Parts For Sale
    Last Post: 12th April 2010, 07:00 PM
  4. roll centre adjusters
    By aeke7086 in forum Technical - Questions
    Last Post: 5th May 2006, 06:37 PM
  5. Roll Centre Adjusters
    By patience in forum Technical - Questions
    Last Post: 22nd January 2006, 11:18 AM
