4age is out of the car i will miss her. sr20 will be going in next week
well the motor was in a ke70 already so im gettig the motor with the ae86 cross member customized and a ca18 gear box thats mounts to a ke70 already so the motor is is drop in n drive umm abt 4500 for motor gearbox haltek comp cooler alloy rad 610cc injectors lift pump surge tank bosch 910 pump and tail shaft for t series
any news of the sr20 progress ?
he got fucked over by another member on here with the sr20 that was intended to go in, but because dans slack, he HAS purchased a redtop sr20 with 78xxx kms, staying stock with a cooler for now, this beast is getting fully engineered. daily driver/track pig is the intention
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
what crossmember you going to use dan? getting all the work done at status or doing it yourself?
T18 in the build
hows dat make me slack im doing verything myself agen umm soz for not answering any1 questions coz i forgot about members rides lol umm bought a stock red top sr20 70,000km on it putting that in next week thats if i sus out how to fit it to my a series cross member. Putting a sr20 box behind it with a custom one piece tailshaft joining to a r31 diff with 4.11 and a spool but before i do anything to the diff or the car im doing everything as stock as possible so i can get the car engineered and registered. my plans after the engineers is
4.11 with spool in a r31 diff need to get
t28 turbs froma s15 need to get
haltech e8 ecu got it
440cc gtr injectors need to get
fuel setup in boot got it
and pretty much just boost the fuker to 14 pounds and get tuned at status tuning
im doing everything myself all i need is a tune dats all
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
NCCE ( Naths crazy corolla electrics )
FATKE & DRFTR86....DOSEING COROLLAS SINCE 2009
gtr injectors won't fid sr rail
T18 in the build
GTR injectors wont work, you will need to use S15 JDM injectors or maybe RB25 ones. Shouldnt need them with 14 psi and a T28, could probably just get away with an adjustable fuel pressure regulator.
DTF - Danzo Technical Factory
good old side feed injectors dan, jace mite have a spare set, hes removing his jdm s15 ones in favor for 850cc sards, overkill for sure
SQ ENGINEERING
NCCE
y the hell does he need 850cc thats rediculous he aint gonna need dat much wats his numba anyway my fones cracked cant see anything
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
