turbo bug i have had the 4age for so long i built it i drove it i got over it
since you dont know the history of this car and i personally helped daniel build this rig from a rolling shell, mr spiderman, this had a na 4age, twin webers, cams, valve springs, p&p, the lot, fully built bottom end, at the end of the day, boost is the only way
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
NCCE ( Naths crazy corolla electrics )
FATKE & DRFTR86....DOSEING COROLLAS SINCE 2009
if it doesnt whistle it aint a missile
SQ ENGINEERING
NCCE
if it doesnt dose your not even close
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
not friendly guys, i was just stating my opinion. no need to chuck several different shades of shit at me. as for the 4a vs sr debate, the sr may very well shit all over the 4a in every way, but i personally detest sr's, due to personal experience with my bluebird ('84 TRX, S13 SR20DE). it broke rockers at every opportunity, completely stock. even with a hks rocker stopper kit. but anyway, good luck with the swap.
josh
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
update u gotta make winton !
yep new update on front brakes im using mazda fd calipers with eg civic slotted discs
also upgrade on the diff which is a r31 skyline diff with a 4.11 and a spool
all i need is a gear box which i cant find im not to sure if ill make winton but will make it for july
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
the bloke who sold u that motor didn't run in the clutch i know i installed it and you'll need to sort out the first coilpack as the bolt holding the coil onto the engine has snapped off and if it comes loose it misses sometimes but this looks like a good build keep up the good work
the dyno pull to 300rwkw
yeh i took the clutch of man im getting a different one coz im gonna have more power i just wanna know overall is the motor in good condition no problems with beside the coil
wat wrong with the coil is the bolt strip or sumfin to hold it in?
CATCH MY DRIFT
SQ ENGINEERING
PROTEK
