it would fit as in the bolts would line up. fit in the engine bay is a different story
will this fit on a 16v with the adapter plate?
I think the quads r upside down with the adapter plate. So I don't think it will work. Maybe if the mounts are turned upside down on the gtir manifold
one of the current jap AE86 drifters uses one for his turbo 20v... i saw it recently in my travels, but is by no means a new idea.
OK we've established that all of you guys have seen/heard/used this before, but does anyone actually have anything to report as far as potential for performance, power characteristics, limiting factors or even a direct comparison to trumpets for example. I'd have thought just looking at it that it would be a bit too small, but might be an ok solution if you do something like what Frak described and increase the volume somehow, or you can use a big piece of pipe on the big inlet tube to increase volume of the system a bit.
So any cold hard facts? Dyno sheets, or anecdotal evidence of any sort?
wtf, this is ae86dc we are on here!
jokes aside I am interested also but who would really test one airbox and then this one after a retune? Even if there are some limits due to volume and all perhaps it's not as relevant when it's this or no option at all.
I will bug this guy I know into making something happen about a batch. If it happens I will fit it to my car as a test run and see how it compares, I better keep my eyes peeled on a the a/r ratio whilst doing so though.
FraK: the way you did it sounds seriously awesome, must of taken a while yes?
How's the availability?
Hi guys, I'll get some pics asap, mine was for FI not NA, I wanted to increase the plenum chamber so I bought a 30mm plate of ally and dumbly decided to mill it out by hand(Sam....took effing ages! especially the inner curves to match the taper of the plenum cover.) I machined down about 24mm to increase the plenum volume. I do not use ram tubes inside of the plenum, I used a cutter in the mill that has a radius on it that was developed from years of development from one of the longest/most wins in IPRA in South Aust. I have been working with these guys for over 20 years, when they have made restrictors I have flowbenched etc to check air flow, they have come up with a radius that works really well so I used this to radius where the backing plate goes onto the quads(if that makes sense)
I also match ported the backing plate to the quads using a mill cutter so it's a perfect match, infact if you run your finger from the backing plate to the quades, you cant feel the step(this is without factory gasket)
The reasons I used the GTiR plenum were these;
asthetically it looks really nice being cast and not just some welded up box
I imagine Nissan put a bit of effort into the design with regards flow distribution considering the GTiR was their homologation rally car(Yeah I know it didn't do to well....hopefully wasn't plenum design problem :p )
I do have this old photo from the original engine mock up just to see how things would fit before I rebuilt the engine etc, in the pic the backing plate is semi finished, it ended up back in the mill to make it a little more asthetically pleasing.
looks relly nice Frak, I admire your perfectionism.
So what did you install it in?
I see you welded up the big outlet off the side, any idea what that originally suited?
