Results 1 to 10 of 10
Thread: s13/180sx brakes on AE86
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default s13/180sx brakes on AE86 (FOR REAR END)
    hey guy, quick questions... has anyone done or know if its possible to fit s13/180sx brakes on a sprinter
    ps. for rear end
    Jason
    Nundah
    Aparently its quite common in Japan...
    Have no idea if thats true or not...
    I'm in the process of doing this to my KE...
    It depends on how you want to do the caliper braket. Wheather you bolt it to the stock location or weld it to the housing.
    If you wanna make it bolt on the useing s13 disc would be easiest.
    But if you wanna weld the caliper bracket then use R31 disc as it has more bake spacing.
    From my quike look at mine it apears that the caliper can only go in location because of the hand brake cable and its large bracket. At the front with the cable and bracket just under the spring perch.
    I also noticed that s13 and factory AE86 rear disc brakes look uncanilly alike.
    john
    nsw
    liverpool
    do-able dude .. i was looking into it before ... get your self a disc rear end to make things easier and then it would be all customs mounts ...if you are running bigger brakes up front i would say that a upgraded master cylinder like a non abs r32 one will be required .
    somthing i will be doing in the near future .
    Reeece
    Casula
    If your going to do the work might as well get r33 gts t rear brakes.. come with internal drum.. Then no need for hydro setup to e brake
    QUOTE=evil86;31439]hey guy, quick questions... has anyone done or know if its possible to fit s13/180sx brakes on a sprinter
    ps. for rear end[/QUOTE]
    Phuoc
    Liverpool
    any how to dos on them going around.. i picked up a set of front and rear 180sx type x brakes for cheap and might be doing conversion soon
    Phuoc
    Liverpool
    does anyone know if s15 knuckles will fit on s13 lca and if it gives more lock any what not
    just use full s15 lca set up will increas lock ceffy owners and the sort do that
    Veteran bigm's Avatar
    Gold Coast
    pretty sute s14/15 LCAs are longer, thats why they get extra lock
    wouldnt work in out cars because they would give even more camber unadjustable than s13 would.
    Veteran slide86's Avatar
    Huw
    Hills
    you can buy a kit on yahoo that has the adaptor plates to run s13 rear discs and calipers. its a full bolt on package.....very cheap and easy
    Phuoc
    Liverpool
    link please
  1. S13 Turbo Brakes, other S13 Stuff (Syd)
    By frogman in forum Nissan Parts For Sale / Wanted
    Last Post: 23rd November 2012, 05:48 PM
  2. Replies: 15
    Last Post: 28th May 2012, 09:20 PM
  3. Replies: 1
    Last Post: 11th October 2011, 08:42 PM
  4. s13 brakes and rotors, other ae86 parts
    By samuel in forum Car Parts For Sale
    Last Post: 5th February 2009, 10:00 PM
  5. 180sx turbo brakes front [melb]
    By evilsub in forum Car Parts For Sale
    Last Post: 15th May 2008, 04:30 PM
