happy to help
hey I dont know if it helps but I don't need this anymore and you can have it for $60
Just re-read your post Sam 28.5mm .Thanks
happy to help
Let me have a measure of my W5x input shafts first mate. Just trying to update the fibreglassing thread.
Ok Sam. I just measured a W5x input shaft off a 3uz hilux. It measured 28.1. If the GM bearing is 28.5, then it is a close fit. If the bearing sits down lower below the spline, it should be ok. Does the unit you have come with a bearing also? Interestingly, the bearing I am using for the T50 measures about 27.7mm.
the end of this unit is a bearing in itself, it's thin as but it must work for the ford guys. I have a document one of the clubman guys sent to me with specs buts that's for the T50
any more news on the w box progress?
Hi Johl, I am still waiting on some bearings from the states. As i said in an earlier post, the bearings I use for the T50 series box is too small for the W series box. i have tracked down a bearing which has about 0.5mm clearance, but i am a bit nervous about using this because of the tolerance. I have drawn up all the bits i need machined no problems. If you are prepared to pay $500, I can easily use a tilton style bearing, but I am trying to source some more economical bearings. They are available. I will update as soon as I have any news. I am waiting for one to finish 3 projects of my own.
Yeh I'm really interested but wouldn't want to pay 500. I'l keep any eye on this thread for any updates
Been burnt too many times with group buys. I can get a pretty good price for the bearings, and I have a CNC mill that will do the machining pretty easily. Once I get everything working well and i am confident it wont fail after a few uses, I will post details. As I have said, i have 3 W series box conversions of my own, and 3 T50 conversions on the go now, so it is worth my while to get this right. If it helps others, bonus.
I have priced the T50 unit, and roughly priced the W series, but I dont dare mention prices or use the word "sell" incase this post i deleted, but the prices are quite reasonable I thought.
