Page 10 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10
Results 91 to 96 of 96
Thread: Hydraulic clutch release bearing for T50 gearbox
  1. #91
    Dec 2013
    Raul
    CA
    Oakland
    United States
    TO REMOVE ADS, PLEASE
    REGISTER OR SIGN IN
    I'm gonna run a 4age silver top 20v and a rx7 fc s5 NA or turbo II transmission.. anyone done this before? Would this work in my ae86?
  • #92
    Mar 2011
    Ali
    Thats not really the point of this thread, unless you are going to use a hydraulic release bearing with your Series 4/5 Rx7 box.
    Personally though, knowing those Rx7 boxes, I would stick with the Toyota W Series, even behind a Rotary.
  • #93
    Mar 2011
    Ali
    Just to update anyone who was curious how I went with my attempt to use the Howe hydraulic release bearing set up from my 1UZ W57.
    I tried to transfer on to a W55 with A-Z customs adapter and T50 Bellhousing.
    A-Z adapter is ~10mm thick, and this is why you have to use a pilot bearing spacer with it.
    Combined with T50 Bellhousing I had to space the release bearing ~65mm to reach the pressure plate, and it did not leave enough collar for the bearing to sit on safely.
    I would have to take ~5mm out of the bellhousing face, and still think it would not work right.
    I ended up doing away with it and just used the JDM T50 bell with slightly modified T50 fork to clear the adapter studs.
    I believe you could set up the Howe unit with a Nitesparts Bellhousing.
    Ed from V-eight.com forums has a nice bolt in bracket that mounts off the input shaft cover for a quarter master unit.
    This type of set up has the potential to work with A-Z set up, as it does not rely on the W series collar.
  • #94
    Dec 2013
    Raul
    CA
    Oakland
    United States
    Hey Jimmy, I sent you a message about your adapter. Please email me at steerandsave@gmail.com (I'm in the US). Thanks.
  • #95
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Digging up an old thread, has anyone ever looked at a concentric slave cylinder off a late Corolla? as in a genuine Toyota one?
    I am going to get one in and check it out.
  • #96
    Oct 2014
    Doug
    Southern Adelaide
    REGISTER OR SIGN IN
    Hi guys, I tried putting a 4age with a t50 in my ke10 many years ago and after many set backs, the slave issue was the final straw. I would love to give it another go if I can source this adaptor you have made up for the SAAB hydraulic unit. I'm located in Australia and very interested....
  • Page 10 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10
    1. T50 release bearing noisy!!
      By bradae85 in forum Technical - Questions
      Last Post: 3rd August 2012, 08:17 PM
    2. Replies: 3
      Last Post: 19th May 2012, 03:34 PM
    3. 4age clutch release bearing
      By harvo in forum Car Parts For Sale
      Last Post: 30th April 2009, 01:30 PM
    4. hydraulic throw out bearing
      By 350hp4agte in forum Offtopic Discussions
      Last Post: 2nd April 2009, 08:02 PM
    5. T50 clutch fork and bearing carrier
      By terryo in forum Cars or Parts Wanted
      Last Post: 24th April 2007, 03:08 PM
