Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 81 to 90 of 97
Thread: Hydraulic clutch release bearing for T50 gearbox
  1. #81
    Dec 2011
    Kerry
    Warradale
    so im gathering that these units all went ahead no issues?
    im interested to know what pricing was/is?
  2. #82
    Jim
    Wodonga
    Ive made a few of these now. Doesnt seem to be an issue
    Part numbers for hydraulic unit. Adapter is separate
    cylinder is 4776308
    bearing is 8721995
    You usually buy the units with bearing, cylinder and dust seal. Local SAAB dealers should stock them, or try wreckers. They are off a SAAB 900 turbo I think. Check that with the SAAB dealer though
  3. #83
    Glenn
    North Ringwood
    hey jimmy how did the wbox go ,has that been finished at all
  4. #84
    Jim
    Wodonga
    Hi Celica RA45, I havent done much more work on the W series adaptor because the Howe unit will work basically out of the box, and I havent got arount to fitting any W series boxes yet. All I would do for piece of mind is have a small sleeve machined to hold the hydraulic unit perfectly concentric. (the small sleeve isn't really needed though). The Howe hydraulic units are available through ebay or just google them. A lot of the Americans use a quartermaster equivalent which I havent had a good look at yet.
  5. #85
    Member z_brutalis's Avatar
    Jun 2009
    Robert
    Kealba
    just a suggestion the clutch slave cylinder from a 2003 lancer fits in through the hole as if it were a clutch fork maby this could help you design a working prototype
  6. #86
    Jul 2013
    Carter
    Florida
    Beverly Hills
    USA
    Hello, I'm a newbie here, it's my first post. I'm helping a guy fit the Mondeo slave to his 4AGE/T-50 setup. Making an adaptor. I Googled to see what other folks have done, and found this great site. I'll post some pix as the project evolves. Thanks, Carter Shore (Beverly Hills, FL USA)
  7. #87
    Moderator Sam-Q's Avatar
    Endeavour Hills
    alternatively you could just buy one off Jimmy
  8. #88
    Dec 2013
    Raul
    CA
    Oakland
    United States
    Any new info on this subject?
  9. #89
    Jun 2011
    Gareth
    Katoomba
    sorry seems neither me or my brother posted back, worked just fine
  10. #90
    Mar 2011
    Ali
    I have a W series box with AZ customs adapter to JDM T-50 Bellhousing and a Howe unit.
    I had to space and shim it quite a distance to set it up.
    I am planning on installing motor and box into KE70 in the next couple of weeks for trial run.
    All looks to be in order.
    Has anyone else got any experience with this kind of set up.
  1. T50 release bearing noisy!!
    By bradae85 in forum Technical - Questions
    Last Post: 3rd August 2012, 08:17 PM
  2. Replies: 3
    Last Post: 19th May 2012, 03:34 PM
  3. 4age clutch release bearing
    By harvo in forum Car Parts For Sale
    Last Post: 30th April 2009, 01:30 PM
  4. hydraulic throw out bearing
    By 350hp4agte in forum Offtopic Discussions
    Last Post: 2nd April 2009, 08:02 PM
  5. T50 clutch fork and bearing carrier
    By terryo in forum Cars or Parts Wanted
    Last Post: 24th April 2007, 03:08 PM
