Results 1 to 7 of 7
Thread: Seam sealer/primer/bog q's
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default Seam sealer/primer/bog q's
    Ok just want to make sure before I do something wrong...
    I just had D seam weld my engine bay and after I went over all the bare metal with etch primer... kinda forgot to go over the seams with seam sealer...
    I'm guessing it will be sweet but want to make sure I can use the seam sealer over the top of the etch primer?
    Also can I bog over etch primer?
    Niz
    BENT MECHANIX - Garage 20:
    Senior Member Simon-KE70's Avatar
    Simon
    should be fine mate, just prepsol the primer and then apply the sealer.
    Niz
    South~Slide Briz
    awesome.. cheers mate
  • #4
    Senior Member addikt's Avatar
    Tyson
    your ment to prime b4 u seal neways buddy if it was bear metal or welds
    Old username : hally
    Beige build in the works!!
    http://www.ae86drivingclub.com.au/fo...426#post874426
  • #5
    Niz
    South~Slide Briz
    true, alright sweet.. thats good then lol
  • #6
    Veteran slydar's Avatar
    Dimitri
    but.. bog goes on the steel.
  • #7
    Niz
    South~Slide Briz
    I thought as much... hmm all good, not really 2 many spots I need/want to do.. Cheers again Dim for the migg'n
    oh yeh - flap disc's ftw, worked a treat
  • Similar Threads
    1. Tomac Primer 220
      By iwantarolla in forum Other Items for Sale
      Last Post: 4th June 2011, 11:30 PM
    2. Better than bog?
      By squish_m8 in forum Offtopic Discussions
      Last Post: 20th May 2010, 10:45 PM
    3. What is used to hold the front guards on....seam sealer??
      By Dongaz in forum Technical - Questions
      Last Post: 29th November 2007, 05:04 PM
    4. BOG...
      By riceburner in forum General Topics (No Technical Questions)
      Last Post: 22nd November 2007, 09:48 PM
