should be fine mate, just prepsol the primer and then apply the sealer.
Ok just want to make sure before I do something wrong...
I just had D seam weld my engine bay and after I went over all the bare metal with etch primer... kinda forgot to go over the seams with seam sealer...
I'm guessing it will be sweet but want to make sure I can use the seam sealer over the top of the etch primer?
Also can I bog over etch primer?
Niz
BENT MECHANIX - Garage 20:
awesome.. cheers mate
your ment to prime b4 u seal neways buddy if it was bear metal or welds
Old username : hally
Beige build in the works!!
http://www.ae86drivingclub.com.au/fo...426#post874426
true, alright sweet.. thats good then lol
but.. bog goes on the steel.
I thought as much... hmm all good, not really 2 many spots I need/want to do.. Cheers again Dim for the migg'n
oh yeh - flap disc's ftw, worked a treat
