Results 1 to 10 of 14
Thread: Are all 4age HG's the same??
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Default Are all 4age HG's the same??
    Bit of a noob question, so excuse my ignorance.
    But i asked greenline to send me a TRD 0.8mm Gasket for a 4age 16v, usually they ask for what motor etc so i stated what mine is: Ae101gze
    I got this reply
    Hi Grant,
    Thanks for your enquiry. After contacting TRD we have been informed that they do not have a head gasket suitable for the 4AGZE.
    HKS have 0.7mm (Currently no stock available) and 1.0mm (limited stock 4 units) head gaskets suitable for the 4AGZE.
    Please let us know if you require further information or assistance.
    Regards,
    Jason
    I would have thought they were all the same, but this reply begs the question...
    lol im getting over this motor being in my shed and not in my car, im half tempted to not bother with the head gasket as last time i changed one it was a massive pain in the arse...
    Ok
    Seamus
    Milton
    4AGE 16V and 4AGZE gaskets are all interchangeable, regardless of year/model
    20V gaskets (ST and BT) are ever so slightly to the 16V versions
    peace
    Ok
    Seamus
    Milton
    so that said, just tell them you have a jdm 16v 4age, it will be the end of your hassles
    Jason
    Nundah
    I have a TRD .8 gasket If you want one asap...
    Just came today and I'm not using it..
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    ive put my 16v and 20v gaskets together the only change is in the water jackets and the blocks are the same anyway they are interchangable. i think they dont do a hg for ze cos they are most likely 1.1 or .13mm not .8mm or .5mm that trd makes. i use .8mm in my turb engines.
    AE86 THE BEST
    Grant
    Gold Coast
    Cool guys thanks heaps, Redwork you got a pm
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I think your wrong, the blocks are the same but its irrelevant, the water flows through the 20v head in a different direction and running a 16V gasket on a 20v engine will mean that the cylenders towards the back of the head will be cooled better than the front on the exhuast side.
    Nathan
    Lilydale
    i agree with sam, i have a stock 20v and a stock 16v gasket here, and the gaskets water jackets are of different design. i wouldnt recommend interchanging them. the head cooling design is so diferent.
    Eddie
    sa
    yeah i said the water jackets in the block are the same and the hg is just adjusting the flow for the head, the block faces are the same. anyway ive always bought trd gaskets as 16v ones.
    what are people using as metal gaskets for 20vs then??
    AE86 THE BEST
    Nathan
    Lilydale
    i havent started my turbo 20v yet, but i got a multilayer metal one from acl, seems good quality.
  1. metal HG's
    By dehney in forum Technical - Questions
    Last Post: 8th October 2012, 06:29 PM
  2. 4AGE 20V 0.5mm or 0.8mm HG
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 9th July 2011, 05:56 PM
  3. 20V 4AGE TRD HG .5mm
    By FAST EDDIE in forum Cars or Parts Wanted
    Last Post: 3rd June 2011, 07:55 PM
  4. need a trd 20v .5 or .8 metal hg in sa
    By FAST EDDIE in forum Adelaide & SA Events and Discussion
    Last Post: 21st May 2011, 12:24 PM
  5. 16v and 20v hg the same??
    By FAST EDDIE in forum Technical - Questions
    Last Post: 11th July 2010, 10:41 AM
