Results 1 to 10 of 15
Thread: S13 SR20det gearbox/clucth issue - wtf is it
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default S13 SR20det gearbox/clucth issue - wtf is it
    Looking to see if anyone can shed more light on an issue that began yesterday with my Daily Feroza running an SR
    After getting in the car after work I noticed a really odd grinding feeling (hard to described accurately, but its not like a crunch when you don't clutch all the way or miss a gear)
    This feeling is felt through the clutch pedal when releasing and also through the shifter when changing fear, most prominent when going from 1st - 2nd - 3rd and a little in 4th, only when the engine is running obviously and the car is moving...
    Down changing this arvo into 2nd I also noticed it was a little crunchy/grindy going into gear.
    I find it odd that it just started happening after the car drove fine all the way to work in the morning.
    The clutch was replaced about 4 weeks ago with a new heavy duty exedy plate and high clamp pressure plate if it makes and difference... The box was filled with Nulon smooth shift 75-90 oil and a tube of G70.
    Any ideas would be much appreciated
    Niz
    BENT MECHANIX - Garage 20:
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Make sure some fuck hasn't dropped ur oil wen u wasn't around ur vehicle
    Mt Macedon
    Hard to say much from what you describe, but could it be a siezed/dodgy throwout bearing. A check for that is that everything will be fine with the engine running, box in neutral and clutch out. Press the clutch in and it gets whiny/grindy/stalls.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    hopefuly flywheel or pressure plate isnt coming loose?!!!
    AE86 THE BEST
    Veteran slide86's Avatar
    Huw
    Hills
    yeah thats what i was thinking.
    A loose bolt(s) on the pressure plate will cause some of these symptoms
    Niz
    South~Slide Briz
    hmm loose bolts, didn't think about that, although they were all torqued properly, flywheel had locktite used as well... so not keen on taking the box out again...
    Throwout bearing is a brand new Nachi item so shouldnt be anything wrong with that, plus it dosnt whine ect.
    The strangest thing is Ive noticed also after driving around some more is that it seems to come and go, like be worse at times and sometimes feels normal.... ???
    I am missing the inspection plate on the bellhousing which would allow debris to get in, but it feels like an issue with the gearsets in the box more than anything, its just not really consistent which is making me wonder wtf
    Also the engine is solid poly mounted which could contribute in some way possibly?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    when you say it comes and goes, its not like when its cold it does it and when its hot it goes away or anything like that is it??
    Dec 2010
    Cal
    my mates s14 made the same noise then boom..but his problem was the input shaft got rammed in and rattle gunned on.
    Niz
    South~Slide Briz
    nope not related to oil temperature, just randomly plays up...
    I think I will be under taking the joyful task of removing it this w.e by the sounds of it...
    Huw
    Hills
    input shaft bearing
  1. Alternator issue - SR20det
    By NIZLAH in forum Technical - Questions
    Last Post: 22nd December 2012, 12:54 PM
  2. S13/!80SX SR20DET Gearbox
    By DR86FT in forum Car Parts For Sale
    Last Post: 10th October 2012, 09:47 PM
  3. cooling issue in ae86 with sr20det
    By slider4life in forum Technical - Questions
    Last Post: 4th May 2012, 09:30 PM
  4. WTF gearbox
    By AwesumaPowa in forum Technical - Questions
    Last Post: 9th December 2009, 08:29 AM
  5. s13 sr20det
    By ca1871 in forum Cars for Sale (Not Toyotas)
    Last Post: 30th November 2009, 05:29 PM
