Results 1 to 8 of 8
Thread: 4A-GE starter motor help
    Default 4A-GE starter motor help
    I need to know if the 4A-c starter is the same as a GE bigport ? . mine is playing up and i may be able to get a 4ac cheap.
    thanks , Roger
    Seamus
    Milton
    nah 4AC is lower amperage, from what i remember
    Veteran slydar's Avatar
    Dimitri
    itll work though. the solenoid is offset slightly different, but will work with most headers. will bolt up and work though.
    Thanks guys , i'll look for the right one then.
    Jonathan
    The 4A-C starter is a normal type Denso 0.8kw starter.
    Some 4A-GEs came with the same 0.8kw starter, only it had a heat sheild. I don't know of any other differences. Maybe the solenoid is over a bit, not sure.
    And some 4A-GEs came with the 1.0kw reduction starter. This is the one that gives the Initial-D/Camry sound on startup.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the 1kw version is that the one that looks like a normal one but has long bolts going down the outside? what about the ae92 one that looks like a 5s-fe with the aluminium housing
    Jonathan
    The 1.0kw reduction starter looks the same as what all the newer Toyotas have (because it is the same). From SV21 Camry onwards. It is sort of boxy and modern in shape, obviously a reduction starter. A larger version of the same design is used on HiLuxs and everything else. When it came on the 4A-GE/AE86 it would have been a fairly new design. Now a industry/Denso standard of what a good starter looks like. This starter also came on some AE93 with 4A-GE. You can use the AE93 one on your AE86.
    The lightweight starter with the 2 external threw bolts, did not originaly come on the AE86. It came on the 20valves (but mounted on the other side). It is a reduction starter, as it has planatary gears. Some late model AE92/AE93 with 4A-GE had this starter, so if you find that one it will fit AE86 also.
    Endeavour Hills
    way to go, I find it amazing that the small aluminium gear reduction starter is still 1kw considering the small size. Oh well all the better for me
  1. 4a starter motor (manual)
    By KePtrick in forum Cars or Parts Wanted
    Last Post: 8th February 2010, 08:05 PM
  2. need 3s-ge starter motor
    By sticks in forum Cars or Parts Wanted
    Last Post: 24th June 2009, 07:08 PM
  3. 4a starter motor
    By tuff te-72 in forum Melbourne & Vic Events and Discussion
    Last Post: 9th May 2009, 07:21 PM
  4. 4a rwd starter motor
    By tuff te-72 in forum Cars or Parts Wanted
    Last Post: 22nd April 2009, 09:23 PM
  5. 4A starter motor
    By skiddz in forum Cars or Parts Wanted
    Last Post: 11th February 2007, 09:18 PM
