Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 39
Thread: WARNING ARP Head Studs- proven wrong
  1. #11
    Tony
    Strathpine
    Quote Originally Posted by takai View Post
    So lets get this perfectly clear. The problem ISNT with ARP head studs, its with a failure to build your engine properly! Your post should read:
    completely missing the point.
    Measure it yourself and make up your own mind!
  • #12
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Quote Originally Posted by trd5k View Post
    Well for your infomation Dickhead, theirs nothing here saying i put the motor together. (splash lubricated) After seeing this, i was right, You are a DICKHEAD
    if i could be Fuc*ed i would answer the rest of ya crap, but i have better things to do.
    Bloody hell, someone has a truely sandy vag today dont they. If you bothered to actually read my post you would see i didnt say you built your own engine. I said it was with a failure to build the engine. Learn your english grammar and you might figure out the difference.
    I couldnt care less who built your precious engine, but the dribble you are spouting about "ITS ALL ARPs FAULT, WOE BETIDE ME" is complete garbage. As i said in my post, your original post should read something along the lines of:
    BE WARNED, if you dont assemble your engine properly, and leave out the head/block dowels you can block an oil passage and undersupply oil to the cam journals
  • #13
    Tony
    Strathpine
    just to add one more thing: This is the third engine i have found that has done this.
  • #14
    Jul 2009
    Vic
    What you said was "its with a failure to build your engine properly".
    A failure, not your failure. The subject of the sentence is a failure, but the direct object is your engine.
    Regardless. The three sets of cams i have (all aftermarket billets) have no oil gallery inside them, and certainly no drillings on the journals to allow oil to flow through. Therefore the ONLY other option is for them to be splash lubricated. I dont have any stock cams to compare with, so NFI there.
    The 4 smallport heads i have here have no groove in that area at all, but i have no bigports, so possibly they have it there.
    In the end the problem lies with the lack of a dowel.
  • #15
    Tony
    Strathpine
    Anthony: oil flow was checked by removing cams first, then the heads untill we had oil flow. the last head i removed the head stud first.
  • #16
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well if this is proven to be a null point then I will get rid of this whole thread
  • #17
    Glenn ke_70's Avatar
    Clay
    Barossa!
    don't get rid of the thread. reword mabey?
  • #18
    Stern but now fucked off...
    May 2005
    Nick
    You guys should treat each other with a bit of respect. That goes for both side of the argument.
    That said, Tony (TRD5K) was racing corollas in NZ before most of you were a stain down the inside of your mums leg! I'm not saying that he never gets anything wrong, but knowing the guy myself and even sitting back watching this debate unfold, I would be taking his advice before any of the other participants in this thread.
    The rest of you morons who jumped into this thread just to add your two cents worth of name calling (and no factual information) can all go and fuck off.
    I will personally tidy this thread up later.
  • #19
    South Island
    Timaru
    New Zealand
    Quote Originally Posted by Sam-Q View Post
    I would say dont get rid of the thread as the actual subject is quite informative.
    But the obvious question I have is which head does this refer to?
    I presume you are talking about the 16V heads not the 20V heads?
    Does it affect all of them?
    Just about to do ARP headstuds on my engine next week as the toyota ones are no longer up to the task.
  • #20
    Apr 2011
    Steve
    It wont be the ARP head studs, My GP A engine has unbrako's for head studs, and we used them in our offroad 4AG engines and never had a oiling problems in 5 years of racing.
    In fact we used to restrict the flow to the head!
    Sprinter Veteran
  • Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    1. Replies: 4
      Last Post: 12th September 2011, 12:12 PM
    4. ARP head studs Q
      By filfilfil in forum Technical - Questions
      Last Post: 2nd February 2009, 12:46 AM
    5. JDM Digital Dash - Warning Rear Lights ???
      By SNAP in forum Technical - Questions
      Last Post: 21st May 2008, 09:26 AM
