Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 39
Thread: WARNING ARP Head Studs- proven wrong
  1. #21
    Seamus
    Milton
    I am using ARP studs on a 7AGE with a 20V head - definitely no sign of oil problems - there's PLENTY of oil getting up there.
    ^ Clicky clicky!
  • #22
    Tony
    Strathpine
    all iam gonna say, is measure it yourself and make up your own mind
  • #23
    Stern but now fucked off...
    May 2005
    Nick
    Thanks Tony.
    All these guys see here is 36 posts and they think you don't know anything. You should post up some of the stuff you've worked on some time.
  • #24
    Senior Member Stain's Avatar
    Derek
    Far North
    Thought I'd chuck some pictures up of this since I checked it during my build.
    Before I start I must stress that my calipers aren't the most accurate things
    so the measurements are purely for guide to show the difference in sizing.
    Oil gallery to the left of the stud (block)
    Oil gallery routed into stud hole (head)
    ARP stud thickness
    Stud hole size
    OEM bolt thickness
    Oil feed inside stud hole (head)
    As you can see the OEM bolt has a much thinner shaft allowing for more oil to pass by it.
    I would have thought that the space left by the ARP stud was enough as the oil feed inside
    the stud hole in the head is very tiny in the first place, but obviously it can be an issue.
  • #25
    Moderator Sam-Q's Avatar
    Endeavour Hills
    good pics, anyone have any opinions on this?
  • #26
    Tony
    Strathpine
    Derek, thats taken into account the stud sits dead centre you would have .4mm roughly round the stud.
    This is a pic of the stud in place. If you have a look at the front of it, you can clearly see its touching the head.(oil gallery for the cams is at the front) The grooves around the sides are from where we used the die grinder to increase the hole size. Even with that and the oil gallery size increased the oil pressure is 1/2 of what is at the block (15 psi at idle and 30 psi at 4000). Also found another person today who's had the same problem.
    Maybe toyota didnt quite getting the machining perfect on all the heads.
  • #27
    Derek
    Far North
    I'd rather avoid the issue all together but I'm not sure the best method to take.
    I wonder if using a standard bolt for this one corner and ARP studs for the rest would effect anything?
    As that would be the easy way out... Other than that maybe re-drill the stud hole to 1.5-2mm larger?
    But I don't know how thick the walls around there are or if there are any other galleries to watch out for.
  • #28
    Endeavour Hills
    I seriously doubt you would run into anything, however getting the swarf out of that small hole though...
  • #29
    Derek
    Far North
    Shoot some compressed air down the other end of it?
  • #30
    Endeavour Hills
    well I guess blowing on the main face up into the head should blow it all out
  • Page 3 of 4 FirstFirst 1 2 3 4 LastLast
    1. Replies: 4
      Last Post: 12th September 2011, 12:12 PM
    4. ARP head studs Q
      By filfilfil in forum Technical - Questions
      Last Post: 2nd February 2009, 12:46 AM
    5. JDM Digital Dash - Warning Rear Lights ???
      By SNAP in forum Technical - Questions
      Last Post: 21st May 2008, 09:26 AM
