Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 39 of 39
Thread: WARNING ARP Head Studs- proven wrong
  1. #31
    Luc
    Seaford
    funny how the proof is here and the previous fighters have nothing else to say on the matter.
  • #32
    Stern but now fucked off...
    May 2005
    Nick
    Agreed...
  • #33
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    If the stud is touching the front of the bolt hole then either your stud is bent or the dowel isnt locating properly.
    Any core shift between heads is irrelevant after machining, because the machining of the head bolts and dowels is done AFTER the head is cast, so casting differences makes absolutely no difference.
    Also, all of my heads here have ~ 0.2mm gap around that particular stud.
    I still maintain its not an issue at all, provided your engine is correctly assembled with dowels in place.
    If it really worries you then simply drill out that head bolt hole to 11mm. That will increase the clearance for the oil gallery, and will only reduce clamping force by a poofteenth (from memory roughly 0.6%) as the load spreading washer is 18mm OD.
  • #34
    Member Golden Circle's Avatar
    Oct 2011
    Clinton
    Hills District
    so can we lay this to rest as to why some people have problems and some dont, asside from the fact that the dowels werent in place?
  • #35
    May 2005
    Nick
    Well, it was at rest until you bumped an almost year old thread... lol
  • #36
    Oct 2011
    Clinton
    Hills District
    yes but it wasn't resolved very well, Wouldn't you agree Nick? The question still remains, Why do some people have this problem and not others? Fair enough that he didn't use dowels,That pretty self explanatory, But what about other people that swear by this aswell? Apologies for the resurrection, it's just got me paranoid enough to bump up 12 month old thread.
  • #37
    Keen to see videos on this. I have a 16v head with the same symptoms / bolts used
  • #38
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I don't see why this is such a problem, you guys should all be checking all these things whenever you modify anything with engines considering how critical oil supply is. I don't mean to sound harsh or condescending at all, but you can never just fit any components and not check everything with any aspect of engine building so these are no different.
    Also, the issues with these stud kits have been a known quantity for a very long time with regards to distributor shaft clearance and the oil gallery and ARP have very little desire to change the product.
  • #39
    Veteran Konakid's Avatar
    Henry
    Eastern
    I have read that this was also an issue with their 22R ARP Stud kits a while back but they have since rectified the issue. Maybe call ARP and ask if they can supply a correct stud for that location or replace with Toyota new genuine or another brand.
  • Page 4 of 4 FirstFirst 1 2 3 4
    1. Replies: 4
      Last Post: 12th September 2011, 12:12 PM
    4. ARP head studs Q
      By filfilfil in forum Technical - Questions
      Last Post: 2nd February 2009, 12:46 AM
    5. JDM Digital Dash - Warning Rear Lights ???
      By SNAP in forum Technical - Questions
      Last Post: 21st May 2008, 09:26 AM
