i will have these parts but need a pic to verify as there are 4 versions of linkages
Hi All,
Chasing a single throttle linkage and throttle cable bracket from Silvertop quad throttle boddies.
Or, the throttle cable bracket from a dual linkage
Also need a throttle cable for an ae82 16v running quads, but yeh.
In SA but happy to pay for postage,
Cheers.
Bugz
AE82 FXGT Daily + AE82 Twinky Project
Thanks for reply.
Ok where im at, i have my silvertop quads on a T3 adaptor plate which turns the itbs upside down from their original orientation.
When i bought my quads the seller only supplied a duel linkage without the cable bracket.
After doing some research i was to believe there were only two varients of linkage, a duel and a single, however now you are saying there are four...
This got me to thinking you might have originally lhd versions? Which would pull from the left orginally but in my case pull from the right .
This would suit me alot better as i wouldnt have to have an extended cable made.
Let me know how your four vary please, and if i have made sense
Bugz
ok do you need the rod as well
i have the cable bracket
No i have the little rod
Hi can you let me know if you have a single linkage set available at the moment
ok are you after the single linkage set up as the rod is different from the dual linkage set up and im away now for 8 days i have both sets in stock and also the cable holders
been very busy sorry
Yup im after a complete single llinkage setup then please.
PM me some details when you can and ill make payment etc.
Bugz
