Items:
#1 - [s]AE92 Genuine TRD 3 point front strut brace.[/s] Sold pending payment
#2 - AEXX series FWD half sized radiator with custom stainless steel lines to suit 16V head. BSP fitting welded to water outlet pipe to suit autometer (and others) temp probes.
#3 - E58 Viscous LSD gearbox, with shafts.. 120xxxkms ran with redline MT90 for the small amount of time i used it.
#4 - Excedy 3 puck cushioned ceramic faced clutch, pressure plate and 4azge flywheel, very little wear on all components.
#5 - 90duro urethane engine mounts, Very solid, i doubt you'll ever break them.. rear mount suits a e58 gearbox
#6 - Whiteline front strut brace for ae92
#7 - [s]Whiteline Heavy duty adjustable sway bars to suit AE92[/s] Sold pending payment
#8 - [s]ISC 30 way adjustable coil over suspension these are the Gold and black bazda type, 8kg fronts and 6kg rears.[/s] Sold pending payment
#9 - Cusco 'PS' Powerball headers, these are the late model ones with the cnc'd flange, headers only.
#10 - Cusco dampened 175mm crank overdrive pulley & cusco adjustable ABV
#11 - SC12 supercharger. half cut spare, good condition
#12 - AE101 levin GTZ superslut brake calipers W/ brand new RDA st185 rotors (will need machining to fit)
#13 - 440cc High impedance injectors, these are modified ford motor sport injectors with the 14mm neck lathed down to suit an 11mm rail.
#14 - FMIC 2.5" inlet outlet [ ] with upper and lower brackets for ae92 factory front ends (uses factory mounting holes)
#15 - 4x 15" steelies (chasers) to suit ae82-92-1XX corrolla's offset is around 38?ish ill confirm this
#16 - 2.5" mandrel bend exhaust to suit ae92, has a TRD muffler on it, amazing muffler, starting to look a little old, stainless tip.
#17 - Front camber bolts to suit ae92/ae101 (lots of other model cars)
Website: Here & toymods
Item Condition:All used
Reason for Selling: Going slideways
Price and Payment Conditions:
All discussions about costs and postage to be via PM only, payments to bank account or cash in hand
As it stands
#1 - $250pp
#2 - $590pp
#3 - $1200pp
#4 - $300pp
#5 - $520pp
#6 - $100pp
#7 - $500pp
#8 - $700pp
#9 - $600pp
#10 - $650pp
#11 - $400pp
#12 - $380pp
#13 - $240pp
#14 - $80pp
#15 - $60
#16 - $300
#17 - $50
Extra Info:
Build thread of car located here:
Pictures:
#1 - SOLD
#2 - rad setup
#3 - e58 lsd box:
#4 - excedy puck clutch and gze fly
#5 - solid engine mounts for aeXX FWD chassis (e58 rear mount)
#6 -
#7 - SOLD
#8 - SOLD
#9 -
#10 - cusco ABV
#11 -
#12 -
#13 -
#14 -
Contact Details:
Here, PM, or mobile 0400933779
Stuff will be added as it comes off the car ^_^
Parts added
also bump
