Results 1 to 4 of 4
Thread: F series info
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    Default F series info
    So the F series thread is locked so just a quick question
    the LSD from Altezza will fit?
    now im guessing its the sxe10 or gxe10 as they are 7.5 inch as is the F series,
    jce10 and gita are 8"
    also the spacer ring i cant find any info on, anyone have pics?
    Mt Macedon
    I put an Altezza LSD centre into an MS112 F series pumpkin and housing. Definitely no need for a spacer ring and, as far as I can remember, no problems with bearings.
    It fits.
    Veteran Skylar's Avatar
    Ken
    I put a cusco sxe10 diff into a tarago diff.
    It fits. Doesn't need a spacer plate. I had a 45mm id centre so I had to get 50mm id bearings to suit cusco, no prob.
    The only problem I did encounter was the axle has 90deg teeth but the cusco has 60 degress teeth or the other way 'round, making the axle loose in the centre. My theory is toyota changed the spline profile on the newer F-series (sxe10 chassis) so the tooth count and diameter is the same but the teeth have a different profile. You can fit MA61 centre into tarago diff, you can fit hilux centre into tarago diff, all old and ~same era but not sxe10. Either that or I got an oddball diff from cusco. One day, I'll check my theory out when I get under a gxe10 and pull an axle.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I am unsure why it was locked in the first place but it has been unlocked now, I will now close this thread, so if possible could all posts be made there again, thanks guys:
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. Info on F series diff ratios above 4.3
  4. t series info
    By Rich_86 in forum Technical - Questions
    Last Post: 9th January 2008, 11:56 AM
  5. Toyota A series info
    By damo46 in forum Toyotas in the Media
    Last Post: 20th May 2006, 11:00 PM
