Pic's aren't working mate
Hey guys. Ive decided i just cant afford to drift.
Hard for me to get rid off but until my finances get better I cant do anything with it.
For Sale
Toyota Sprinter AE86
Engine Bay
4agze with forged pistons. Upgraded rods. Stage 2 Cams SR20 Throttle Body with 7M intake Manifold - Was put it just before round 2 2009 and has not been driven since round 5 2010. Water pump timing belt and tensioners all brand new. All gaskets and seals brand new when put in. runs extremely strong, serviced before and after every event without fail
T25 Turbo of S13 with High Mount manifold
Dump pipe and exhaust to suit
FMIC
Injectors are of a 3SGE
Oil Catch Can
Nistune ECU.
3A Racing Pod Filtre
As little wiring as possible used
Engine only has what it needs to run to keep weight down
Drivetrain
T50 Gearbox. 3rd Gear is gone. Selling as is
Exedy 5 Puck Clutch
TRD 2-way LSD
Suspension / Handling
TRD Fully adjustable coilovers on front in Tein Sleeves
TRD rear shocks and springs
Power steering arms fitted for extra lock.
Negative RCA
Front Strut brace
Rear Strut brace with harness points
6 point roll cage
Adjustable Panhard Rod
FC Caliper Upgrade on front
Adjustable Castor Rods
Interior
Fully stripped interior painted in white
Custom Aluminum Dash
Custom aluminum door trims
DEFI Water Temp & Tachometer
Bride Fixed back Driver seat
OMP Deep Dish steering wheel
KSport Hydraulic Handbrake
1.5l Surge Tank
Exterior
Factory
Wheels
Numerous wheels. range from 14" to 15"
SSR Meshies will not come with the car unless negotiated.
Bad parts.
Right hand side has been hit. I have new door. But needs new front Fender, indicators and rear panel needs to be knocked out.
Gearbox has lost 3rd gear.
Some mild repairs needed to be done to exhaust housing on turbo
Only mods really need left to be done to be real competitive is W58 Gearbox. T28BB turbo and a retune.
Car makes 220Hp atw at the moment. Always been reliable at the track. Even with high temp outside car still stays cool and can keep going where others have to pull in.
Carbon Fiber Bonnet was damaged as well. So will not have that. Will have factory bonnet.
Selling for $6000. Fairly Firm on that price as this car is worth way more than that. But need the cash so is the reason im selling it so cheap.
Car is currently held at KYP in Welshpool.
Can call me on 0414 919 405 or pm me on here.
ADM AE86 Levin
facebook pics dont work
Pics put up. Sorry about that.
bump
bump
Sold
