Weekend bump.
Some may have seen this for sale on Melb gumtree but for sale I have a manual conversion package.
Parts list.
AE71 manual T50 gearbox, with shifter, bellhousing, clutch fork, thrust bearing carrier and clips
AE71 manual T50 gearbox crossmember
AE71 manual tailshaft (needs new front universal joint)
AE71 manual pedal assembly
AE71 manual clutch master cylinder
AE71 manual hard clutch line, with chassis bracket
AE71 manual soft line
AE71 manual slave cylinder
AE71 manual gearbox stays (bottom of bellhousing to engine block)
AE71 manual speedo cable
AE71 manual exhaust bracket
AE71 front section exhaust
AE71 crossmember, with engine mounts and steering rack
Working low KM 4A-C engine complete from fan to flywheel/clutch (come hear running)
AE71 throttle cable
$1000
Motor needs front cam seal replaced and clutch may as well be changed before install too. Other than those things this is a pretty complete little package and I will not seperate individual items. Could possibly sell the manual conversion seperate from the motor and 4A crossmember but price wont change much. Can hear engine running in car, as it's the only part from the above list which is not from the stripped car. Engine will come out of my pano as soon as buyer pays deposit.
I'm located Northern suburbs Melbourne & can deliver within reasonable distance (melb metro).
Contact via PM.
I thought I had this sold before advertising but the guy hasn't contacted me so it's now available for sale.
Weekend bump.
To those interested the clutch master cylinder, soft line and slave cylinder are all near new items.
Back to page one.
if you decide to separate I will take the pedal box
yeh second that if you seperate i'll take the gearbox crossmember
thanks!
Won't be seperating until I have buyers for most parts lined up first.
would you seperate the whole manual conversion? If so how much?
750ono
would you sell just:
AE71 manual speedo cable?
