Go to a brake shop for pads. Get them to machine your rotors too. Problem solved
Hey, front brakes are squealing like hell! want some of the factory anti squeel plates that go on the calipers.
Also after some rear sway-bar mounts/brackets for T18 T series diff, and anything else that is involved in fitting a rear sway bar to a T18, as I am unsure what else is needed, and obviously a rear sway bar preferably a larger one than stock ke/ae one.
Also unusual but a good KE70 steering shaft.
Not in any rush for the sway bar stuff but would like to stop these squealing brakes soon.
Brand new pads and rotors, and have a disc lathe at work anyway. Pads have been bedded in, just need the anti squeal plates also have antisqueel paste stuff that we use at work to use with the anti squeal plates.
