Results 1 to 4 of 4
Thread: head gasket for 20valve in rwd???
    Aaron
    Default head gasket for 20valve in rwd???
    if you were to run a 20v in rwd with rwd water pump and setup pretty much as a 16v 4age would you use a 16v head gasket or a 20v head gasket???
    i had a look at the head gasket for a 20v and other than a bypass i have at the back of the head and the top hose outlet there isn't much in the way of alot o flow thru the head.
    just curious on peoples opinion in the matter
    Senior Member shelldrake's Avatar
    Eddie
    Ripponlea
    If your whole cooling system is setup like a 16v, use the 16v gasket. I'm using one in mine...
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Quote Originally Posted by shelldrake View Post
    while that is correct it is a very easly misunderstood comment. Yours needs the 16v gasket because your cooling system is the only one of its kind on this whole forum. However anyone else using some kind of rear bypass (internal or external) for the water would still need to use the 20v gasket.
    Aaron
    cheers sam
    btw thanks
  1. WTB 20valve HEAD MELBOURNE **VIC**
    By Eightsix. in forum Cars or Parts Wanted
    Last Post: 21st July 2012, 03:34 PM
  2. WTB: head gasket
    By trd4ag in forum Cars or Parts Wanted
    Last Post: 5th April 2010, 05:24 PM
  3. Head gasket
    By Hazzard in forum Technical - Questions
    Last Post: 27th October 2009, 10:33 PM
  4. TRD .5mm rwd head gasket part number required...
    By shelldrake in forum Technical - Questions
    Last Post: 11th August 2008, 09:21 PM
  5. 4age ARP Head stud Kit, toda 0.8 mm head gasket
    By rxbenny in forum Car Parts For Sale
    Last Post: 10th July 2007, 11:50 PM
