Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Speedo drives
  1. #11
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Bozy I am making this a reference from the technical index, and I eddited your original post to suit, if you prefer it to not be then let me know and I will delete the whole thread.
  2. #12
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    I have no problems with it, could be usefull information for others in the future!
    ADM AE86 Levin
  3. #13
    Aug 2012
    Jarrad
    east
    Adding some information here as it is in the index of technical threads.
    Thought speedo cable questions would be an appropriate place to put this info as well.
    If you are wanting to get a new speedo driven gear assembly, you need these two part numbers:
    Sleeve that goes into the gearbox: 33404-16010 (comes as a sub-assembly including o-rings)
    Gear - to suit a 3.9 ratio (stock):33403-19155 (comes as a sub-assembly including an o-ring and clip)
    Other ratios are available with different part nubmers.
    N refers to number of teeth in the nylon gear.
    33403-19135 N=19
    33403-19155 N=20
    33403-19165 N=21
    33403-19175 N=22
    (To work out ratios/what you need etc. Look at this thread too:
    http://www.ae86drivingclub.com.au/forums/showthread.php/22529-speedo-gears )
    Extra parts in the pic aren't needed. Didn't realise they came as sub-assemblies. So save yourself some cash.
    My question:
    Do all manual AE86 have the same speedo cable?
    Mine was originally 4AC and the cable seems too short. Am I missing something? Is this correct?
    The bend is quite harsh and it doesn't seat into the holders.
ID:	36589Click image for larger version.
  1. Yokohama S drives and the likes, after feedback
    By Rice86 in forum The Drift Channel
    Last Post: 12th September 2012, 12:10 PM
  2. wtb: ke70 that drives for cheap
    By milan_ke70 in forum Cars or Parts Wanted
    Last Post: 19th May 2011, 09:50 PM
  3. Replies: 11
    Last Post: 30th January 2011, 03:56 PM
  4. Ke70 speedo drives
    By grape_moosha in forum Technical - Questions
    Last Post: 16th February 2007, 09:32 PM
