Results 1 to 10 of 10
Thread: powersteering arms
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default powersteering arms
    a bloke i know thinks that using powersteering arms on a manual rack messes up the scrub radius and bump steer, shed some light on this knowledge?
    Veteran slydar's Avatar
    Dimitri
    no. it doesnt. the steering arms are from the same car, and a power steering car has the same rack position. both set ups are "factory" geometry.
    the bump steer characteristics might be slightly altered. scrub radius not at all, ball joint pivot is not moved.
    Jonathan
    The "power steering" arms plus manual rack is the factory combo used on the AE86 GTV.
    (But the GTV rack itself is a different part number, not sure how it's different).
    Either way, scrub radius is not effected.
    性交を愛する
    Who told you this? (like background etc)
    Dave
    Western Suburbs
    i just wanted to prove to a guy i been speaking to, he wants to buy an ae86 for hillclimbing days, but seems to think even though it for the same car since its a smaller knuckle or w.e will cause bump steer problems along with scrub radius probs
    even though i know shitall about geom i knew a few smart cookies lurk these forums and they wouldnt do this mod if it caused these problems someone like jonny rochester is probably one of the people id trust knowledge from easily
    Gone
    Joel
    Picton
    id like to know the difference between a GTV rack and a normal rack, ive got both on the floor of my garage now.. look the same from the outside
    Dimitri
    quicker ratio as i understand it. rare part, hard to track down in this country.
    seems to be the case though. there are definitely differences in rack ratios.
    ive noticed it when centering the rack for initial set up of the car. you wind it to lock, then wind back the other way, note the turns, and try to get it in the middle. some jap cars have a slightly quicker steering ratio.. less turns lock to lock.
    Jason
    Southern Suburbs
    Standard: 3.5 turns lock to lock
    GTV 3
    Quaife: 2.5
    GTV is nice and good budget upgrade. Have been running one for a number of years. Not as heavy as Quaife, which are farking heavy when the car isn't rolling.
    The arms on GTV's are the same as power steering. Shorter arm effect's ackerman angles.
    Senior Member ToySprinta's Avatar
    Steve
    Wentworthville
    Will noticably improve bump steer if you are running NCRCA's
    Dave
    Western Suburbs
    i run rcas but i got cambertops anyway
  1. Wtb: AE86 Powersteering arms or just standard arms
    By Sherlock in forum Cars or Parts Wanted
    Last Post: 11th May 2010, 01:54 AM
  2. powersteering arms
    By w84me in forum Technical - Questions
    Last Post: 11th August 2008, 09:46 PM
  3. AE86 Powersteering Arms
    By AUS086 in forum Car Parts For Sale
    Last Post: 21st May 2008, 12:40 AM
  4. ae86 powersteering arms
    By w84me in forum General Topics (No Technical Questions)
    Last Post: 3rd April 2008, 05:36 PM
