was it throwing gears before you changed your clutch and gearbox oil?
also how much oil did you put in the box and where did you fill it from?
when you took the selector out did you make sure it went in with bush on?
Bit of a strange one, just done the clutch in the car, & replaced the Gearbox Oil etc, went for a trash tonight & the box was throwing gears right from the start, 1st Mostly then 2nd, The tunnel seemed to get very hot.
Then all of a sudden this strange episode stopped & the car drove well for another hour. Sounds stupid but would the gearbox oil effect this at all, I put 80w in. Surely its a wore syncro that is the cause of this problem but why would it stop?
the only thing i can think of, maybe if you messed with either the spigot bearing, (in the crank) or the release bearing carrier guide (the thing the input shaft goes through).. the spacer behind there.
seeing as you did the clutch maybe you replaced the spigot bearing.. didnt push it in far enough, and it was putting pressure on input shaft.
or you left the spacer out, after replacing the seal?
either of those things could maybe miss align the clusters...?
guessing. just suggestions cos you did the clutch.
Ok, I left the release bearing on (felt good) as it was very tight & I had basic tools & little time, didnt mess with anything else. But I did for the 1st time fill the box from the top after I had bolted everything up, it was a time thing once again. about 1.8 Ltrs Wasnt throwing gears & isnt now!
ok
i have filled a t50 from the top before and found it didn't drain properly into the box straight away but took awhile to drain into the main body of the box
i pulled apart a t50 not long ago andwhile there is a drain from the rear to the main shell the drain is very small.
more than likely when you first drove it there was fuck all oil in the box and as you drove it it drained down.
my theory anyway
It took the oil very quickly, but yes thats a definate possibility.
Im starting to like option A, its cheaper! Yes thats it conversation over...
As I said as the start it was odd, happened tonight at Archy drift practise, messed up the 1st 10 runs easy, then spent the next hour trying 1 handed shit, then it was ok, enjoyed the rest of the night. Drove home not problems
If you have trouble going into gear, with a slight click or crunch (or even refusing to go in at certain speeds), then you have a worn syncro. And your new oil is thicker that you were using. This can sort of be fixed going back to thin oil.
If the gearstick is going out of gear by itself while driving, then that is less common and means something very bad is up. Like worn dog teeth on the gear itself, and worn selector hubs. (Or hopefully just a rock or something jaming the shift linkages).
Yes, in 1st 2 hands on the wheel while driving the car is now in neutral mother fcuker, give it 2nd & its out again
That was pretty much it for a while... I was pissed off as I have a spare T50 in the shed.... But as I said it took alot of track time after it stopped throwing gears with 100% no problem
