Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: heat from tunnel
    Veteran ae86's Avatar
    Western Suburbs
    Default heat from tunnel
    was reading another tech problem and this reminded me of something that worries me, some day i can feel heat on my left leg from the tunnel like fairly hot heat i got carpet n sound deadening too so its through that, should i be worrying or checking something ?
    Jonathan
    And the exhaust is on the left side? Look to see where the exhaust goes and how its clamped. Exhaust leaks?
    Senior Member Brendan's Avatar
    Brendan
    what's engine Temps like when u feel heat? Hot days or any day? Have u felt the actual floor when u've felt the heat on ur leg? Not a dodgy heater?
    Nathan
    Lilydale
    im assuming 4ac?
    You didnt buy 80s leg warmers of STYLZ did ya?
    Western Suburbs
    its a jdm 4age bigport 3rib, temp guage always saying its at mid temp so i dont know what it could be caused by, sometimes its on average degree days, exhaust is on left side, standard jdm exhaust system. i might get it checked for leaks i guess
    oh if only, wouldnt have been 500 down the clappers and woulda been more usefull than this piece of shit diff.
    Western Suburbs
    anyone?
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i used to get this in my last ae86. my left leg would always warm up then hurt on a long drive. figured it was normal because i had an old ford whos transmission would warm up as much on a nice drive
    Veteran blair's Avatar
    Blair
    SEQ
    yeh its definitely not normal guys. i cant see it being exhaust related as it runs down the other side, could be g/box related as above...
    next time it gets real hot see if you can get under there and feel/see whats actually getting hot (apart from the tunnel obviously)
    Western Suburbs
    cars about 6cm off ground and i dont have a jack that gets straight under there =\ normally takes me about 10-15 mins at home to get car with a jack under it,
    clutch slave is on my side could that create the heat?
  1. firewall trans tunnel modifying. How much is too much?
    By Evocom in forum Technical - Questions
    Last Post: 31st December 2009, 08:12 PM
  2. 4ac heat issues
    By shakes in forum Technical - Questions
    Last Post: 27th August 2008, 02:49 PM
  3. WTB rain tunnel rubbers
    By ae86 drifter in forum Cars or Parts Wanted
    Last Post: 24th August 2007, 03:15 PM
  4. deletas 20v ae71 screaming through a tunnel
    By dr1ft-pig in forum Toyotas in the Media
    Last Post: 12th June 2007, 10:40 PM
  5. Russian Tunnel
    By julzy in forum Offtopic Discussions
    Last Post: 27th February 2006, 09:39 PM
