Results 1 to 7 of 7
Thread: setting lash on cams.. can i get away with a few being loose?
    Veteran slydar's Avatar
    Dimitri
    Default setting lash on cams.. can i get away with a few being loose?
    doing the shims in my head today. just wondering if its gonna hurt them cams (they are brand new) to run them loose at all.
    i would dearly like to put a few run in k's on the engine this weekend (also has fresh rings and bearings) and just wondering if its ok to run it like that.
    and by how much?
    intake tolerance is 0.15-0.25mm. exhaust is 0.2-0.3.
    just ive always heard loose is better than tight.. and but brand new cams need to be "work hardened" or whatever.. wondering if running them slightly loose will adversely affect this process?
    sa
    victor harbor
    Do the cams come with any info about running them in.
    The info sheet which came with my Tighe cams which I never ended up using, said to run the engine at 2000 rpm for 20mins when fist running the engine with new cams.
    Dimitri
    yeah but what i need to know, is as im running them in, is them being .1 to maybe .3mm too loose gonna kill them?
  • #4
    Senior Member KE70's Avatar
    Alek
    Lalor
    If no-one from the forum knows, maybe a few calls to some head reco places?
    But make sure you get a few of the same answers before you go ahead with it, lol
  • #5
    Dimitri
    yeah. i just ordered the right shims. theyre being over nighted. theyll be here tomorrow.
    i kinda decided if its less than .05 out i wouldnt be too worried anyway. but i couldnt get it within that with the shims i have.
    fucking annoying actually, they cost $10 each. should have prepared better and got lots of em from the wreckers. the same shim is in 7ms and gen1 3s which there are heaps of at the wreckers.
  • #6
    Aaron
    with running it in i would recommend having them spot on. mostly because alot of cams wear in from the valve spring pressure pushing on the cam with the shim or bucket in between.
    if you dont have the right clearance your not going to provide enough spring pressure on the lobe face.
  • #7
    Mason
    Salisbury East
    Hi mate
    I'ts ok to run them slightly loose (not too loose)
    especially if you have had head Reco'd :the seats
    cut & valves ground as the valves do bed into the seats after a while.
    As I'm in the trade and have set up alot of DOHC engines
    slightly loose to avoid valve overrun.
  • Similar Threads
    1. Loose steering.
      By odessy in forum Technical - Questions
      Last Post: 13th September 2011, 05:42 PM
    2. Help front seats too loose!
      By McLEVIN in forum Technical - Questions
      Last Post: 16th July 2011, 12:50 PM
    3. Accelerator pedal loose
      By li21 in forum Technical - Questions
      Last Post: 20th May 2008, 12:48 AM
    4. lead keep comin loose
      By awang in forum Technical - Questions
      Last Post: 10th September 2007, 10:25 PM
    5. Loose Change
      By unit101 in forum Offtopic Discussions
      Last Post: 17th June 2007, 07:17 PM
