Results 1 to 10 of 14
Thread: Help now asap emergency (insert other in your face words)
    Default Help now asap emergency (insert other in your face words)
    does anyone know where or if there is a diagram on how to pull a diff centre out of a ketto. there is a guy coming round in an hour to weld mine and i need to get the centre out and cleaned up!!! someone help!!! better yet if your on the sunny coast some help me please!!!!!!!!!!
    Jonathan
    Take both axles out.
    Take back cover plate off.
    Lever the thing out with a big bar. Note what shims are on either side. (Some workshops have a diff spreader to stretch the housing apart, you don't have this).
    i mean how do you take the axles out....complete noob need noob english explination
    Jonathan
    Take wheels off
    Take drums off, may need 2 M8 bolts if its tight.
    Take shoes off. Disconnect brake tubes maybe.
    Use a socket, 14mm, undo the 4 nuts seen behind the brake shoes. Pull axle out.
    Veteran johl's Avatar
    Johl
    i wouldnt be welding on a centre that just came out. i'd wanna let it dry over night unless u like fires
    how do i get the drums off?
    Senior Member adam's Avatar
    Adam
    Put hand brake down, turn the drum until it slides off.
    Axles could be a little hard to take out as well, could require a slide hammer or just put drum on backwards, put two nuts on, turn nuts 3 times each, and slide that like a slide hammer.
    Senior Member Toy-Yoda's Avatar
    Weld the center while it's still in the diff?
    I've done that before, just keep a damp blanket handy JIC.......
    Josh Curwen, 26/02/1987-26/10/2008, the world is a lesser place without you, you will be missed little Fox, game on..........
    Quote Originally Posted by 7shades
    If traction and articulation won't get you there, speed and stupidity will
    Member of the Leaf Sprung Axle Trampers Club
    Click me for epic jump video I is used the force.......
    West
    A good trick if the axles are stuck is to bolt a length of heavy chain onto the wheel studs and then use the heaviest long metal object you can find to slide hammer it off by ripping on the chain. Works awesome with a car on a hoist or securely sitting on stands.
    Veteran Robo86's Avatar
    Rob
    i just put the drum back on but flipped and throw 2 wheel nuts on then proceed with the hammer time
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  1. i have no words......real rap stars
    By slide86 in forum Youtube Chan
    Last Post: 23rd January 2010, 12:45 PM
  2. Emergency Trailor repairs
    By Blair in forum Offtopic Discussions
    Last Post: 23rd August 2008, 08:26 PM
  3. Emergency: Broken down in broadwater.
    By flamingheads in forum General Topics (No Technical Questions)
    Last Post: 6th June 2006, 09:48 PM
