Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: 4agte piston and conrod question
  1. #11
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    ok mr bigport i got a 7 rib block, would that be a small port bottom end or did the bigports come out with 7 rib too???
    (sorry not trying to hijack its all on topic so why not ask here )
  • #12
    Senior Member mrbigport's Avatar
    Craig
    Canungra
    7 rib is smallport, gze, or 20v
    all ran the bigger crank
    slight variations in pistons between weights, design, and materials used but all have the same hole sizes (as far as i know).
    pistons changed between the different variations obviously...otherwise we wouldnt be having this discussion lol
    4agte KE70 263.6whp
    QR Sprint Circuit 1:02.9
    QR Sprint Circuit 60.7 (turbo)
    QR Clubman Circuit 1:06.41 (first outing NA)
    QR Clubman Circuit 1:02.77 (turbo)
    http://www.ae86drivingclub.com.au/fo...ustom-Stickers
    full colour windscreen banners from $45!
  • #13
    Michael
    Crimebrook 2749
    thank you very much
  • #14
    Senior Member sld sho's Avatar
    Sep 2010
    Ozman
    Broadmeadows
    what is the beneifit of haveing a 7 rib block apart from beeing able to put gze parts in there, what difference is there if you just get forged pistions and conrods for the other block 40m crank?
  • #15
    Craig
    Canungra
    its a stronger block - short answer...more ribs give it greater reinforcement against both the internal preasures (especially under boost) and the twisting forces aka torque twist
    this is a photo of a 3-rib 4age.
    http://www.rschita.gr.jp/4ag/image/4ag-002.jpg
    this is a photo of a 7-rib 4age block.
    http://www.aeu86.org/download/4age-7...k/id/12102.jpg
    ultimately its the stronger bot of gear, and its quite obvious once you see the difference in them
    4agte KE70 263.6whp
  • #16
    Davey & Riki-lee
    South Australia
    Seaford SA
    200kws on a stock (so i think) bottom gze end, loves it
    Our introduction - Click here
  • #17
    Veteran Skylar's Avatar
    Ken
    Quote Originally Posted by mrbigport View Post
    Just a little correction:
    you can get 7 rib with big port. They were in early AE92 and very late AE82 and look like:
    That one's been converted to RWD. The difference between them is that bigports are normally black and blue writing on the inlet cam cover but 7 rib bigpot is black and red with smallport being all red writing with spark plug cover further down the valley and not at the top like bigports.
  • #18
    Craig
    Canungra
    fair call, but as a general guide for someone hunting a 7 rib block...
    4agte KE70 263.6whp
  • Page 2 of 2 FirstFirst 1 2
    1. 4a piston question
      By trikzlane in forum Technical - Questions
      Last Post: 23rd February 2010, 11:09 AM
    2. conrod nut torque
      By chuckY_ in forum Technical - Questions
      Last Post: 5th July 2008, 05:38 PM
    3. Conrod cap bots - tools
      By AE86_4life in forum Technical - Questions
      Last Post: 11th May 2006, 11:02 PM
    4. ARP conrod bolts
      By Hachi Roku in forum General Topics (No Technical Questions)
      Last Post: 11th April 2006, 04:56 PM
