Results 1 to 6 of 6
Thread: RWD 4a backing plates, auto/man
    Rob
    Moorabbin
    Default RWD 4a backing plates, auto/man
    Are 4ac backing plates (the thin plate between gearbox and the engine) the same between auto and manual?
    Also is the starter motor between auto and manual the same?
    Thanks
    Rob
    Jonathan
    The plates are different. The auto one has an inspection hole, so you can undo the torque converter bolts.
    I am not sure if the starter is in the extact same place or not. It would come close.
    Rob
    Moorabbin
    Thanks Jonny,
    So can an auto plate be used with a manual gearbox? (with the inspection blocked up)
    Also, is the starter motor itself the same? ie can I get an auto starter (say out of an auto ae71) and use it on a T50?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Quote Originally Posted by RobertoX View Post
    Thanks Jonny,
    I dont see why the sandwich plate couldnt be used. The starter motor will be fine
    Rob
    Moorabbin
    Thanks sam... I It would be different if the bellhousing flange between the auto an manual are different. I'll check it out this weekend, there's an auto ae at centre rd
    Endeavour Hills
    well its going to be easier for you to find out now that I took the engine mounts off that engine and left a seat belt there on the engine hooks to lift it by, hehehehe
    also I have a starter for sale for $20 if your interested
  1. Need adm 86 Front backing plates
    By zookieboi in forum Cars or Parts Wanted
    Last Post: 22nd July 2012, 11:44 PM
  2. ae86 backing plates
    By josh.. in forum Cars or Parts Wanted
    Last Post: 18th February 2012, 05:34 PM
  3. URGENT ae86 backing plates
    By ke70dave in forum Cars or Parts Wanted
    Last Post: 20th July 2010, 09:48 PM
  4. AE86 brake backing plates
    By AJPS in forum Cars or Parts Wanted
    Last Post: 15th April 2010, 12:33 AM
  5. 4A-C RWD auto question
    By vivioman in forum Technical - Questions
    Last Post: 8th May 2009, 09:13 PM
