Results 1 to 5 of 5
Thread: Fuel pump wiring
    Mar 2011
    Scott
    Banyo
    Default Fuel pump wiring
    Hi there guys. I have done 95% of the wiring for my conversion. I'm using a std ae86 ecu & engine loom .
    I'm wiring the fuel pump relay. I've worked out how to wire a relay to prime engine & run while engine is running.
    What i need to know is the polarity of the "Fc" output. Negative or positive trigger.
    Any help would be great.
    This is a pic of how I will wire the relay.
    Mar 2011
    Scott
    Banyo
    I've just had a further think about wiring like this. It will not be correct ,as if the engine stopped while the ignition is on the relay would disengage & power would keep feeding the pump from 87a. I will wire 87a to the starter trigger wire.
    Veteran Skylar's Avatar
    Ken
    See attachment: Car will run but the fuel pump will be slow to come on as the starter has to move the crank and cam before the fuel pump starts pumping.
    The factory way has another relay with the start wire acting as a positive trigger with the power "in'' and "out" the same as the first relay.
    Veteran Nikkojoe's Avatar
    Tom
    Pic in my wiring guide (FC= COR wire and is earthed when active).
    Mar 2011
    Scott
    Banyo
    Thanks for the reply's guys.
  1. EFI fuel pump wiring, help please
    By ian6375 in forum Technical - Questions
    Last Post: 17th August 2013, 04:23 PM
  2. Intank fuel pump wiring
    By Matt in forum Technical - Questions
    Last Post: 31st January 2012, 11:07 PM
  3. Help with fuel pump wiring
    By -=GOODY=- in forum Technical - Questions
    Last Post: 29th July 2008, 07:34 PM
  4. Fuel pump wiring
    By Sparkle86 in forum Technical - Questions
    Last Post: 3rd September 2007, 08:25 AM
  5. fuel pump wiring
    By driftster in forum Technical - Questions
    Last Post: 19th February 2007, 11:58 AM
