Results 1 to 9 of 9
Thread: diff chatter in LSD's
    Senior Member shinny's Avatar
    Liam
    Default diff chatter in LSD's
    Hey guys, i've recently had trouble with diff chatter in my LSD and i just thought i'd share how i fixed it.
    After fitting my diff with TRD 2-way to my car i replaced the oil with the Toyota LSD diff oil,
    after a while it began to chatter under light throttle around corners,
    Don't know what it sounds like??
    diff chatter sounds like the axles are trying to ratchet themselves as you turn a corner, it can be pretty nasty
    The fix?
    i drained a little bit of oil out of the diff and added 'Limited Slip Axle Lubricant Additive'
    its a GM additive used for Holden LSD's.
    After a few laps around the block the chatter became significantly quieter,
    If you're having similar issues, give it a crack.
    Part# 1052358
    (remember its a GM part!! most Holden Dealers should stock it)
    Veteran slide86's Avatar
    Huw
    Hills
    yeah this is good shit, i use it all the time at work
    have a few bottles sitting at home too
    Liam
    personally i havent used it much before,
    but it definitely worked a treat on my diff.
    i might have to acquire a few bottles if i ever want to change my diff oil in the future,
    Senior Member orido's Avatar
    Orido
    outtheback
    is this stuff the same as anti friction agent
    Ford have a similar product, but there may be a cheaper and easier option, just go to a carpark somewhere and do some reverse figure eights, this helps circulate some fresh oil through your clutch plates and stops them glazing up(similar to when the bores glaze up in your engine). I hope this helps.
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    sweet i might have to try this.......the old kaaz chatters a little.
    John 1:12
    West
    Uncle chop chop says, chatter means shes tight. Just accelerate a touch harder so it locks up and spins the inside wheel.
    Tom
    SOR
    Or you can replace your Toyota oil with Penrite Limslip 85w-140 oil that will fix the chatter completely does it for me anyway
    me personally.. i like the sound of locker chatter lol
    chirp chirp chirp chirp chirp chirp chirp chirp lol
    1983 ae71
    1984 ae71 with ke70 front
    1983 ae86
    ke ford laser with massive doof lol
  1. where to get lsd for corona diff?
    By goose101 in forum Technical - Questions
    Last Post: 24th January 2013, 06:11 AM
  2. t18 diff with lsd + new 4.5
    By Evan in forum Car Parts For Sale
    Last Post: 7th February 2009, 11:11 PM
  3. WTB: LSD Diff
    By Jazz9 in forum Cars or Parts Wanted
    Last Post: 10th July 2007, 10:52 PM
