Page 20 of 26 FirstFirst ... 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 191 to 200 of 253
Thread: Wheel fitment thread- post your will this fit questions in here
  1. #191
    ryan
    why should i adjust the the castor rod before i adjust the lca? i know when you adjust the lca first with out lengthening the castor rod, it will start to give you negative castor. But then you fix it by adjusting the castor rod out to give you positive castor. btw im running 2.5" toe out and 2.5"of camber and pretty high castor.
  2. #192
    Moderator
    Jay
    lol no i mean instead of the adjustable part of the lca being where it is, that should be kept standard, then the lca's should be lengthened after the where the castor rod mounts to it which will give you more clearance
  3. #193
    Veteran johl's Avatar
    Johl
    It doesn't look like you are running much castor because you haven't even trimmed the front of your guard. I think from memory anything over 5 degrees was hitting my old guards
  4. #194
    Veteran Konakid's Avatar
    Henry
    Eastern
    What extra lcok modifications have you done?
    Mine had AE86 powersteering arms and 185/60 14x8 -0 with 10mm longer lca's, +4 castor and no rubbing issues.
    Is it rubbing on the chassis or suspension components? What size tyre are you running?
  5. #195
    ryan
    ah k i think i get what you mean, as the lca is adjusted out the angle of the caster rod changes and gives you less clearance.
    its sort of eye aligned at the moment, its just clearing the guard at the front when turning. Probs need to trim the guard and extend it out more.
    i've got cut and shut jdi knuckles, an ajps lock spacer on the passenger side and 5mm slip on spacer on the drivers side. ive also had more teeth cut into the steering rack for more rack travel. i run a 195/50/15 on a 15X7 -1. At the moment its only scrubbing the caster rod on full lock, but i think if i run some spacers it should clear it for now.
    I'm pretty sure a 14X8 -18 should clear fine but am also thinking about whether it will fit inside the guard. the wheels i'm looking at are O disk () so negative 18 offset could be more like -24 offset in A disk (most wheels). so it could look pretty mexican :/
    Anybody tried a 14X8-18 on the front of a ke before?
  6. #196
    Aug 2010
    Sutho Shire
    closer to 0 the beter,but its not the end of the world unless you plan to do serious laptimes,just dickin round and drifting would be fine,ive run a -27 on my 86 before my current mk3's which are neg 8 and car drives alot better and still with tuff look,just pull gaurds futher,its a good size wheel for e7's and 86's most run that or similar
  7. #197
    Henry
    Eastern
    the more neg offset on the front generally will make it handle worse and feel shitter to drive. I personally think that amount of lock is too much as like you are experienceing you run into all sorts of problems and have to compromise in other areas of the setup when you never really use max lock in practice.
    To cure your problems go the -18 and run a 185/55 tyre, should be fine.
  8. #198
    Glenn ke_70's Avatar
    Clay
    Barossa!
    thats some serious lock your trying to achive there.
    i suggest lots more lca length and castor.
    all you gotta do is look where its hitting and find a way to increase the gap as much as possable
  9. #199
    Chee
    SOR
    Slightly off topic here but which manufacturers still make decent 14" tyres? I've only come across the Toyo R888's and the Bridgestone RE001's.
  10. #200
    Clay
    Barossa!
    re001's are discontinued now. unless they've started makeing them again?
    i use 185/55/14 595's. i rate them fairly well.
  1. The Wheel Fitment Thread
    By Konakid in forum Technical - Rims & Tyres
    Last Post: 8th March 2016, 07:43 AM
  2. Wheel clearout - 13",14",15",18"
